Old 03-06-2007, 06:40 AM
daman daman is offline
Shaky gas gauge???
On my '99(old body style) 1500 4x4 the gas gauge reads but it shakes
a little, is there a fix to this maybe new cluster or wire contact problem
or do i need to drop the tank and put in a new sender..
any thoughts??
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 03-06-2007, 04:09 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: Shaky gas gauge???
If the OBS is the same as the NBS, it would be the sending unit.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 03-06-2007, 07:12 PM
Ok i tore the cluster out today and removed the glass, now i wonder if it
would be just that gauge ,,because if you take and move each needle
with your fingers they all have a little drag(resistance)except the
gas gauge that one moves real easy you can just spin it around freely.
that drag is what keeps the needles from shaking i think??
also somone told me you pull your cluster out and send it in to fix that.
any thoughts on this anybody????
Old 03-07-2007, 06:14 AM
Sonny01's Avatar
Sonny01 Sonny01 is offline
It's probably the sending unit in the tank. Do a search in this forum and you will find many many posts.
Old 03-07-2007, 07:09 AM
I did..thats the first thing i did before posting, couldn't find anything
about my turck just the newer body style problems..
no matter i know where the problems now is at....
Old 03-07-2007, 09:43 AM
777stickman 777stickman is offline
Daman: My '98 Sub does the same thing. Reads right, just has the "jitters". There was absolutely no difference when I changed the pump/sender assy. My wiring was good and the ground by the tank was cleaned. Hope you'll post back with a fix............Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-07-2007, 11:23 AM
Sonny01's Avatar
I understand...your problem is a new one on me...sorry I couldn't help you.
Old 03-07-2007, 02:02 PM
No problem Sonny thanks.
stickman,
thank you for posting you saved me time and $$ replacing the
sending unit.
now i don't know 100% for sure but like i said i think it's in the cluster
and the gas gauge alone,,somone also told me that on that
cluster you need to send it in for repair so they can fix the gas gauge
on it, so i'm not sure when i'll send it in i need the truck every day and
can't have down time right now..
stickman you may want to check into this also
Old 03-08-2007, 12:37 PM
NoRiceHere01 NoRiceHere01 is offline
my truck had a little shake, but the guage also did the thing where it just drops to empty every once in a while and to reset it i had to put in in neutral and back to drive.when my fuel pump went and i replaced the sending unit it fixed the problem for a while but it came back.the gas guages on these trucks just seems to be a mystery
Old 03-08-2007, 12:38 PM
Old 04-11-2007, 04:21 PM
problem solved!!!!!!!
Well i fixed my problem,it was as i described bellow
it's the gas gauge it's self,i picked one up off
ebay and checked it with my old one and like i said
it had no resistance(drag)to the needle when i moved
it with my finger,i switched over the odometer and
installed the new cluster and the gauge works
perfect!!!, so i would suggest you guy's may want to
do the same if you have this problem with your 96+ trucks.
somehow the stepper motor that runs that gauge burns
up and just moves freely and that's why it shakes.
Old 04-11-2007, 08:38 PM
klinn klinn is offline
Can you post the ebay information for others that have the same problem. Thanks
Recertified ASE Master Tech.
Certified GM Tech.
7+ years GM dealership experience
15+ years in the automotive industry
opcorn:
Old 04-11-2007, 08:41 PM
It was just a compleat cluster...
http://cgi.ebay.com/ebaymotors/ws/eB...7084664&rd=1,1
