Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-06-2007, 06:21 AM
CA333605 CA333605 is offline
Need Help..
I HAVE A 1996 OLDS, AURUOA.. INSTALLED NEW STARTER/SOLENOID+BATTERY. WHEN YOU TURN KEY ON, THE VOLTAGE LIGHT COMES ON AND STAYS ON.. THEN WHEN I TURN KEY OVER, LIGHTS GET DIM, STARTER CLICKS THEN NOTHING... ACTS AS IF BATTERY IS DEAD... ALSO CAN HEAR A CLICKING NOISE BACK WHERE THE BATTERY IS LOCATED WHEN TRYING TO START CAR... NEED HELP PLEASE..
Old 03-06-2007, 12:32 PM
ghutchin ghutchin is offline
Re: Need Help..
Sounds like you have a poor connection to the battery, either the positive or negative leads.
Old 03-07-2007, 06:02 PM
55624096 55624096 is offline
Re: Need Help..
Have determined that the electrical grounding gets poor as age advances. Have found that if you add a 6AWG wire between the coil base and one of the bolts on the "passenger side" strutt mount your grounding problems will be fixed. Have done it on 3 roras with great results, starts up immediately. Recommend you also go to battery ground cable clean it and the bolt where it connects to the body.
Old 03-08-2007, 06:01 PM
Silver Blue '97 Silver Blue '97 is offline
Passenger side turn signals don't flash
I had to replace the small bulb on the right side. When I want to make a right the front and rear bulbs comes on(but don't flash), and the right side bulb goes out. When the turn lever is in the neutral position the bulb on the right side is on, as is the other side. The left side works fine.
