Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-06-2007, 06:10 AM
ls954's Avatar
ls954 ls954 is offline
voltage question
ive notice that when i drive my car the voltage meter on the dash reads all the way to the right almost to 18 volts but when i come to a stop it drops down to the half way mark at 13 volts and the lights sorta dim down. How much voltage am i suppose to be reading and should it be fluctuating like that?
By the way the battery is new and the alternator is fairly new and in excellent working condition according to the alternator test that was done at the autoparts store
1988 Caprice Brougham V8 305
2001 Monte Carlo SS Limited Editioin Pace Car.
Old 03-06-2007, 09:31 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: voltage question
It should never exceed 15 volts under normal conditions. It sounds to me like the voltage regulator went bye-bye. This is internal in the alternator, have it checked again.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-06-2007, 08:13 PM
ls954's Avatar
heres couple of pix of what the gauge reads. The first one is what it reads when im driving and the second one is what it reads when i come to a stop and the lights dim down a bit. Is it suppose to go down that low and fluctuate like that?
Old 03-06-2007, 08:38 PM
silicon212's Avatar
Confoundingly Lucid
Well, that isn't almost to 18 volts. Yes, that's normal behavior if you have your lights on etc.
Old 03-07-2007, 01:42 PM
theobern's Avatar
theobern theobern is offline
your head lights should not dim, usually they will dim if the idle is low, bad ground or something. Its probaly not a bid deal but it could be a worning sign.
theobern ~ 195K
