Go Back   Automotive Forums Car Chat > BMW > General Discussion
Old 10-06-2002, 05:33 AM
letsgetiton letsgetiton is offline
Top side Oil Changer????
A site has a Top Sider Oil Changer. This is the description: Do an oil change in less than 5 minutes without lifting your car or crawling around on the ground! The BMP top side oil changer is so simple you'll wonder why it wasn't available sooner. With a few strokes of the high volume vacuum pump you'll build up a vacuum in the storage canister. Insert the suction tube into the cars dip-stick tube, release the check valve. The top side oil changer will remove all of the oil from your engine. No more oil slicks in your driveway! Large 8 quart capacity will handle most cars.
Is this any good for $50.00?????
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
