2001 24 Valve Wagon I dunno???
I have a beautiful 24 valve 2001 taurus wagon with all the toys and 126K on the dash. Here's the thing It shifts fine but they'll be times that I'll let go of the accelarator and step on It again then once I feel It gain maybe a second after a small jerk will follow and the thing Is It shifts fine and overdrive picks up wonderfully. Also occasionally I'll fell a similar jerk while I'm driving normal. I really like this wagon and I just got It so I don't wanna sell It so guys please HELP!!!
Re: 2001 24 Valve Wagon I dunno???
How long has it been since the transmission filter has been changed? If you don't know how to do it, you can get it done at most garages for less than 100 bucks. Some will certainly have a different opinion here, but in my opinion any tranny with over 100k, could use some Lucas when the fluid is changed.
Football Guy |
You may want to have the diagnostic codes pulled and see if you have a P1100, Mass Air Flow (MAF) sensor intermittent.
If you have a steady hand, you may want to attempt to clean the MAF sensor elements with MAF sensor cleaner. You'll want the anti-tamper Torx bits to remove the sensor from the housing. These bits and cleaner should be available at your local auto parts store. -Rod |
I'm not sure when was the last time the tranny filter was changed but It needed some tranny fluid so I added a lucas.But I'll look Into It to see If the change Is need and I'll check for those codes although no Warning lights are on the cluster but you never know!! Thanks guys very helpful also How the heck do I reprogram the Keyless entry again??
To get the steps to reprogram the keyless entry key fobs, check the owner's manual or go back to the Taurus forum main page and use the "Search this forum" feature towards the upper right. Seach for keyword "programming" or similar.
-Rod |
Unfourtanely No codes are giving during diagnostic and all the motor mounts are fine but some one told me It could be the TPS Sensor??? Not sure what that Is??? What do you guys Think????
I think you'd have a poor idle if it was the TPS.
'97 Windstar 164,XXX '99 Taurus 159,XXX S.E. Michigan |
Mine was hesitating and idling rough so I cleaned the MSFS and it went back to normal. One step at the time here, clean the MAFS then let's go from there. Another thing, has the tranny oil and filter been chaged and if so when.
If you don't know you must assume it wasn't done and we like to see it chaged 50K miles at most. If you don't know how to clean the MAFS use the search engine and punch in "clean MAF or MAFS". Just spray the clenmer on the tiny wires and DO NOT TOUCH or rub them with anything. http://www.automotiveforums.com/sear...RID%3A11&hl=en |
