Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 03-04-2007, 12:44 AM
r_2016 r_2016 is offline
Exclamation heater/ac question
Today was kind of a warm day around 57 so i decided to run my ac for a few min to cool the car down. I heard a few small bangs come from inside the dash(middle) and then it stopped(The air was comming out cold)then I shut off the ac. When I got out of work after about 13hrs of the car sitting it was cold so I decided to run the heater. When I ran the heater I could hear that banging again (did it the whole way home) even if I shut off the heater......The air comming out of the vents is warm but the sound is annoying. Any sugestions?
Old 03-04-2007, 09:33 AM
sreilly77's Avatar
sreilly77 sreilly77 is offline
Re: heater/ac question
Check the blower make sure nothing got sucked in. Also is there a constant flow of air coming through like is it not blowing real hard then real soft? if there isn't a constant flow, then your blend door actuator which controls how much air comes through might be opening and closing while you have the air condition on and the heat, which may be why you are hearing a banging noise.
Sean
Old 03-04-2007, 04:17 PM
Exclamation Re: heater/ac question
Hi, I put the system into test mode and I got code "024" which is a bad belnd door acuator. Do you know how much it costs to fix this problem. Thanks for your help. Randy
Old 03-04-2007, 08:09 PM
sreilly77's Avatar
i've honestly never done a repair on a blend door actuator before nor have i had to have it done to any car i've owned, but i know on the town cars they are on the passenger side if you take out the glove compartment you will be able to see it clearly.
Sean
Old 03-07-2007, 07:44 PM
Yes, it was the BDA the part cost me $30 and the labor was $650.00.
Old 03-08-2007, 07:44 PM
sreilly77's Avatar
OH WOW!!!!! That is crazy! What did they have to do to get to it did they tell you at all?
Sean
Old 03-09-2007, 12:06 AM
Towncar's Avatar
Towncar Towncar is offline
It's about 3.5 / 4 hours taking the dash apart, 100% labor.
The BDA is situated so that you can see it behind the glovebox but you can't touch it. To get to the mount screws the dash needs to come off, well.. mostly off.. you can pull it back on that side once it's all loosened up.
Even so, the farthest screw can't be reached very well.. some folks break off that 'boss' and mount it with just three screws.
-Steven
1996 Town Car, Cartier
Old 03-09-2007, 05:14 PM
Yes, it was all labor the part was something like $30 or $35 and the rest was for them to put it in. They told me that they had to remove the whole dash board to get at the BDA. I took the car down to the shop at 8am and I did not get it back until 5:30pm.
Old 03-10-2007, 01:33 AM
sreilly77's Avatar
Let me ask you this: Do you have a passenger side air bag? If so, then that is probably one of the reasons the labor probably cost so much. Taking apart the dashboard is tedious but simple. It's taking out the air bag that can be difficult.
Sean
Old 03-10-2007, 12:45 PM
97TaurusGuy's Avatar
97TaurusGuy 97TaurusGuy is offline
Send a message via AIM to 97TaurusGuy
How did you put it into test mode?? I am having a similiar problem with the 1997 Limo I drive.
"Save water, shower with a friend"
Old 03-10-2007, 04:42 PM
Towncar's Avatar
The On-Board Diagnostic can be initiated at any time with any resulting DTCs displayed. Normal operation of the system stops when the On-Board Diagnostic is activated.
To enter the On-Board Diagnostic, press the OFF and FLOOR buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer going around the center of the display window. The test may run as long as 30 seconds.
To exit On-Board Diagnostic and retain DTCs, push the blue (cooler) button. The control will exit On-Board Diagnostic, retain all DTCs and then turn OFF (display blank).
To exit On-Board Diagnostic and clear all DTCs, press Defrost button. The vacuum fluorescent display window will show 000 and all function symbols for one second. Then, the EATC Control will turn OFF (display blank) and all DTCs will be cleared.
The On-Board Diagnostic should be deactivated before powering the system down (system turned OFF). Intermittent DTCs will be deleted after 80 ignition switch ON cycles after the intermittent condition occurs.
-Steven
Old 03-11-2007, 10:38 PM
Yes there is a passenger side airbag. When I put it in test mode my code was "024" for a faulty blend door actuator. Are you getting a clicking sound from your dash?
Old 05-05-2007, 05:52 PM
I am currently having this problem with my 1997 Limo. i am getting a 024 code and clicking the dash. Was wondering if you found a fix yet?
Old 05-05-2007, 07:41 PM
Towncar's Avatar
You missed post #5 where Randy describes his cure....
-Steven
Old 05-05-2007, 09:35 PM
Oops, sorry, thanks for pointing me back to the right direction!!
