Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-03-2007, 09:51 PM
98camarordr 98camarordr is offline
Exclamation 98 camaro keyless remote programming
hey everyone I NEED HELP!! i cant seem to find programming instructions for my 98 camaro keyless entry system. if anyone can help it would be apprieciated!!! I know my camaro is equipped with a factory keyless entry system. so if anyone can help me out it would be highly apprieciated!!!
Old 03-04-2007, 05:07 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: 98 camaro keyless remote programming
Transmitter Programming
Important
All transmitters which are to be recognized by the body control module (BCM) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Turn the ignition switch to the OFF position.
Remove the RADIO (#17) fuse.
Cycle the ignition switch from the OFF position to the RUN position 3 times within 5 seconds. The BCM will confirm entry into the programming mode by performing the following actions:
Locking both of the doors.
Unlocking the driver's door.
Releasing the rear compartment lid.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter for approximately 15 seconds. The BCM will confirm the programming of that transmitter by performing the following actions:
Repeat the previous step to program up to 4transmitters.
Replace the RADIO (#17) fuse.
Operate the transmitter functions in order to verify correct system operation.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 12-20-2016, 08:46 PM
jnunez4 jnunez4 is offline
Hello all!
Trying to program a key fob for my 98 Camaro SS and found this post. I followed the directions as noted, I removed the radio fuse, cycled the key and I get the lock, unlock confirming it enters the programming mode. I then hold down simultaneously the lock/unlock buttons on the remote for 15+ seconds but nothing happens. I then replaced the battery on the remote and still nothing. Any other suggestions or ideas what might be wrong? I do have the stereo head unit disconnected at the moment... not sure if this might be causing the issue? Any help would be surely appreciated!
Thanks,
JC
Old 01-31-2017, 08:16 AM
rhandwor rhandwor is offline
https://www.youtube.com/watch?v=Fl60ztA_kAc
