Vehicle died and will not turn over
1999 Saturn SC2
Mileage 94,000 Help me out on this if you can..... This car was cruising along at about 50 mph, and everything shut down. Engine died, lights dimmed and the whole nine yard, or that is the story as it was told to me by the 16 year old girl. When you turn the key you get a single tick. It doesn't sound like that of a starter though. We attempted to jump it, and again, nothing. Hoping someone can give me some insight as to what is going on. The vehicle belongs to a family that is close to us, and due to some unfortunate circumstances (a fool on a bobcat) is going through a rough time, and I'm trying to help out. Thus, not a whole lot of information for you folks but hoping that you can point me in the right direction. Thanks.... |
Re: Vehicle died and will not turn over
Could be wiring. happened to me once. test the battery for a start. sorry i'm not much help.
1998 Chevrolet Blazer LT (95% stock) Pioneer AVH-P7500 DVD receiver 12" Alpine Type-R in a sealed box PIAA Super Plasmas GT-X bulbs PIAA Xtreme White bulbs K & N drop-in filter ![]() "Melo" and "AI". Enough said.
check the wiring on the underhood fuse box they have been know to go bad
Take the battery cables off the positive and negative. 8 mm socket. Look for corrosion/ buildup. Clean as appropriate and re-install. Follow negative wire to ground. Ensure good contact at grounds points.
Sounds to me your alternator went bad, and was running off the battery until the battery completed died. something like that happend to me in a truck I owned.
Replace the Alt and the Battery..should be good to go.
![]() ![]() 2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running. |
