Old 03-03-2007, 08:27 PM
PlayStation3 PlayStation3 is offline
Can someone confirm this for me
ok i need someone to help me confirm.
here is a copy of the owners manuel for my dvc 2 ohm type r subs.
http://www.alpine-usa.com/images/pro..._SWR-1222D.pdf
the manuel says that each voice coil is a 1.85 ohm now can i buy like a 2 or a 4 channel amp and wire each voice coil to the amp is series and get a 1.85 ohm load to a channel? and would that hurt the sub if it is being powered like that.
Old 03-03-2007, 10:15 PM
dbfreak147.5 dbfreak147.5 is offline
Re: Can someone confirm this for me
as soon as you put power to your subs the impendance will jump up to 2 ohm just wire them to 2 ohm a channel unless you have a mono block and then just series them to 2 ohm and into the amp, your subs are pretty much 2 ohm
2 Orion HCCA 10'S
2 AudioPipe 3k's
Adam Whitehead
Old 03-03-2007, 11:23 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Yes while if you round the numbers up the its 2 ohm. But you cant change the impendance of a sub, so im not quite sure what you meen by "as soon as you put power to your subs the impendance will jump up to 2 ohm". While some amps wont know the difference, otehrs that might be ore sensitive will go right into protect mode. WHile not all subs are wound to there perfect impendance rating some amps arent as critical as others. Kind of like the JL w3 that was 3 ohm, it would work on 4 ohm amps as long as they where 2 ohm stable but 4 ohm amps that werent stable to a lower impendance would go right into protect.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 03-04-2007, 01:44 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
resistance and impedance are two entirely different terms
