Old 10-06-2002, 01:19 AM
myk888 myk888 is offline
Send a message via ICQ to myk888
Angry Need help!!
Hi,
Just need some help on something and i hope u guys in the know can help. A friend of mine has got a nissan, its MPFI,
but thing is..its really weird...
when the car is rev'ed a little bit (like 2000rpm) the car goes mad and the engine starts to (how can i explain it?) jump? its like its misfiring or something...or fuel isnt getting in or something..
Do u guys know what kind of problems that it might be..
my guess was
either: 1.)fuel filter/fuel pump/injectors
2.) The dizzy/or plug wires
Its not the battery, alternator was replaced recently its not the spark plugs...just dont know what it is!!!
Old 10-06-2002, 01:37 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Need help!!
Originally posted by myk888
Hi,
my guess was
I just had a similar problem on my civic.
When it's running, pull each plug, one by one. If you pull one, and the motor bogs down. You know its firing. If you pull one, and nothing happens. You know that wire isnt firing.
My situation was the 3 and 4 wires were dead.
Hope that maybe helps?
Old 10-06-2002, 05:35 AM
MKS MKS is offline
Could also be somthing in the dizzy ... had a very similar prob with my saab ... turned out to be the rotor arm in the dizzy ... was cracked to hell and stopped the engine firing properly ...
1989 Toyota Supra 3.0i Turbo
150mph I think I'm nuts
Custom S/S Exhaust 5" Tailpipe
K&N Induction kit
Bailys Piston Dump Valve (WOOSH)
Wategate Shimmed by 5mm ummm boost
