Old 03-03-2007, 03:26 PM
Ron Ott Ron Ott is offline
1997 Ford Taurus Power Steering
Problem with power steering that is stiff with partial power assist. I've replaced rack and pinion, PS pump, ball joints, all hoses, power steering pressure switch and power assist actuator and problem still persists. Any suggestions!
Old 03-03-2007, 03:59 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 1997 Ford Taurus Power Steering
Look for a filter in the line under the left front frame area. If filter is plugged, the fluid can not circulat properly.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-03-2007, 04:17 PM
Sorry, forgot to mention new oil filter was included with new hoses.
Old 03-03-2007, 09:07 PM
TaurusKing TaurusKing is offline
Damn, sounds like an awful lot of money spent so far.. here's a couple more,, how about the steering column shaft, bad bearings???, maybe the flex coupling is bad, wheel bearings could be an issue, but seems like those would have been checked already..
Old 03-03-2007, 11:24 PM
footballguy footballguy is offline
Keep in mind I am not an advisor here or prefessional tech by trade, but I just went through the same thing on my 1999, just not as extensive (Thank God). I replaced the pressure hose, power steering pump, and the rack. Did it all myself for close to 400 bucks. I don’t even want to think what all that would have cost you if you had it done in a shop. First thing that pops in my mind, is bleeding the system. You replaced a lot of parts and it’s going to take some time to bleed all the air out of that. Hell, it took me a few days to get all the whining out and you've replaced a few more things than I did. The next thing that pops in my mind was my worse fear and I hope your steering column shaft isn’t bad.
Edit: I thought about this some more and I think it's highly possible you have a faulty rack. Did you buy a refurbished rack or a new rack?
Football Guy
