b16 Throttle Body swap
I just finished this mod. i got a b16 throttle body from a friend for 15 bucks and it bolted right on. we measured the b16 TB and it was 62mm, and if you check aftermarket parts, a 62mm TB cost about 300 bucks so i'd say its definately worth the money.
The only modification we had to do was reroute a vacuum line from the fuel cannister. the two coolant lines plug right in as well as the MAP sensor and TPS. THE TEST: I drove the car home after putting it on and i definately noticed the car sounds a bit louder and revs harder, and i havent even ported the manifold yet. that is a job for tomorrow when i finish completely i'll have to let you all know how it works out.
Re: b16 Throttle Body swap
Wow, that's pretty cool. *starts looking for new throttle body* Also, what do you mean by porting the manifold? Will you be putting up pics? I mean, I thought porting was a precise process. |
how to port your manifold:
put the b16 throttle body gasket on your intake manifold and draw a line around the inside of the gasket onto the intake manifold. then grind the manifold as big as the circle you drew and about 1" into the intake at a nice smooth slope. Its probably easiest to take the intake manifold off the car when you're porting. One more piece of info: my stock d16z6 throttle body had the letters GR stamped onto it. my b16 throttle body has GF stamped into it. |
Damn, thts pretty cool..... Yo, does this add power? if so, how much are we looking at? because thats a pretty good mod if you ask me......
88 DX Hatch SOLD! 90 Si Hatch Wreck'd :Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!! 96 Saturn SL2: Daily Driver untill 91DX is running! 91 DX Hatch: Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!! ![]() Official 4th Gen OG Hype Race Crew |
it adds power for sure. thats why they sell aftermarket throttle bodies of the same size. i dont have access to a dyno or i'd tell you exactly how much. the throttle plate is actually bigger than my stock TB so it lets more air into the engine. more air = more power
yes, slightly more but not enough to warrant a giant upgrade in the fuel system like a turbo would be. i belive that with a mod like this, the sensors themselves would make the ECU make the injectors bring in more fuel since its not such a substantial amount of air that it would overload the sensors.
ohhhhh.......... <----POSTWHORE
