Old 03-03-2007, 12:20 PM
pvisser pvisser is offline
Send a message via MSN to pvisser
Bypass AC?
My AC Pump on our 97 Lumina is toast.
It squeels while the car is running. I know there is no R134 in the system.
My question is this, Is there a way to stop the squeel without replacing the pump? or is there a belt out there I can get to bypass the AC?
Dealer says this model only came with AC, and therefore will not look for another type of belt.
Thanks
Paul
Old 03-06-2007, 02:18 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Bypass AC?
here is a link to Dorman's website, which shows the part you need. It's called an a/c by-pass pulley, and should be available at Advance/Auto-Zone, etc...
https://www.dormanproducts.com/cgi-b...rid=0x0032a3ab
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-07-2007, 05:55 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Bypass AC?
I don't know how much you want to get into it, but unless the compressor locked up while running and shotgunned the system with metallic debris, it could be worth the effort to throw a salvage yard compressor and a couple of new o-rings on it, get it evacuated and get a suicide kit and charge it up...I know I can't live in summer without A/C here. Maybe different where you are.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 03-08-2007, 09:00 AM
luminasrus luminasrus is offline
Re: Bypass AC?
Just take off the belt and use a piece of string to measure the length you need to skip the AC. be sure to have the correct belt routing. Then go to the parts store and tell them what length you need, they will fix you up.I've done it.
