Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-03-2007, 11:55 AM
dddaaa dddaaa is offline
replacing crank sensor '92 cutless ciera s 3.3
What does the harmonic balancer look like?
I found the crankshaft position sensor but cant pull it out...do I need to remover the lowest spindle to access it?
Old 03-04-2007, 08:07 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: replacing crank sensor '92 cutless ciera s 3.3
the harmonic balancer is on the end of the crank shaft.
It is round and heavy
Thier should be two screws/bolts holding on the sensor.
Should pop right off.
1999 Grand Am SS 3.4 OHV
Old 03-04-2007, 12:49 PM
The bolt in the harmonic balancer is very hard to loosen. I have a breaker bar but wont loosen. Can I spray something to loosen it like WD40 (and can I spray it to get to where the threads grip?
Old 03-04-2007, 02:46 PM
IT is going to be tight, and you may need a pipe or something on that breaker bar.
The torq specs for that are 100ft lbs + 75 degrees.
Here is a link with some more torq specs.
You can use WD40 or what ever, but you do want to be carefull not to slip when you try and remove the bolt.
As the lubricant can make things slick, you can end up rounding off the bolt head, and thats not good.
hope that helps
Old 03-06-2007, 12:20 PM
Thank you for your advice, it is much appreciated!
I am not working on the car until the weather warms a little as it is soooooo cold here but I am worried about something:
1. I turned the harmonic balancer with the serpentine belt disconnected. Would that of thrown off my timing (will the block now not be aligned with the head)? And if so how do I properly retime the car?
hope that helps
