Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 03-03-2007, 10:39 AM
Gems Gems is offline
Stuck open thermostat
I've been going crazy with this problem for a couple of weeks... The engine would not come up to temperature... I had recently installed a 180 degree "Fail-safe" thermostat, so I didn't think it was the problem... So I changed the ECT sensor but still had the same trouble...I pulled the "Fail-safe" thermostat and it's stuck open... The car has never even come close to an overheat condition, so this must be a defective thermostat... I put in a standard 195 "Stant" thermostat and all is normal again... Just an FYI for all...
Go Mark Martin!
Old 03-03-2007, 11:43 AM
2005chevimpala's Avatar
2005chevimpala 2005chevimpala is offline
Re: Stuck open thermostat
How do you guys get the pictures posted on here, I cannot find antway to post any pics.
Old 03-03-2007, 11:47 AM
I save the pics on "photobucket.com" and then copy and paste the "img" link from photobucket...
Go Mark Martin!
Old 03-04-2007, 06:55 AM
57chevyragtop 57chevyragtop is offline
Send a message via MSN to 57chevyragtop
What Brand was this "failsafe" thermostat? And, you say it only lasted how long? Also thanks for the photo posting info. D`
Old 03-04-2007, 06:59 AM
It's a Motorad brand... It was in the car about 6 months... Supposed to be good quality...
http://www.motoradusa.com/
Go Mark Martin!
Old 03-04-2007, 01:21 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Bad decision Bob.
Stick with the AC Delco only on a SII 3800.
AC Delco Premium Line Thermostat:
180 - 12TP4D
195 - 12TP4E
Timeslip 08/12/06
AF Community Guidelines
Old 03-04-2007, 01:31 PM
Originally Posted by bnaylor
Bad decision Bob.
180 - 12TP4D
195 - 12TP4E
Yup, bad decision for sure... I sent an email with the pic to Motorad (for what's it worth)... Right now I have a generic STANT 195 degree t'stat installed... I ordered a GATES Premium 180 deg t'stat from RockAuto... Is the GATES as good as the AC Delco, or should I go to Chevy and buy the OEM part?
Go Mark Martin!
Old 03-04-2007, 03:18 PM
BNaylor's Avatar
I really don't know about the Gates brand thermostats. I only use the Premium Line AC Delco ones, however, not the standard like stock. I've used Stant thermostats before and had good luck with them. I like the Stant radiator caps too. Supposedly better than the stock AC Delco RC-27 cap or crap.
Timeslip 08/12/06
Old 03-08-2007, 08:05 PM
The Gates 180 degree t'stat arrived today... The cars been fine with the Stant 195 t'stat so far... But here's a stupid question for you...
It appears that the rubber gasket (seal) for the t'stat goes around the perimeter of the t'stat flange and then you drop the t'stat and seal into the c'bore hole on the engine... At least that's the way I installed the Stant t'stat and it seemed to fit properly and it does not leak... Is that correct?... I'm used to seeing the gasket go either just above or below the t'stat flange...
Go Mark Martin!
Old 03-09-2007, 04:49 AM
Well, That's the way it worked on my 92 Lumina 3.1 ltr. The rubber O-ring seal on the thermostat (Stant) lasted 8 years and may still be working as I sold the car 2 years ago. I have never had a problem with Stant and I have used many over the years in many different vehicles. When I first saw the Motorad on Two Guys Garage, I thought it was a neat Idea, but only if it works...I appreciate the heads up from your post. Those Guys promote the Tornado gas saver device too, and you know that is nothing but "snake oil" money down the drain. D`
Old 03-14-2007, 07:51 AM
Well my next cooling system issue started this morning... With the new t'stat and ECT the engine has been coming up to temperature properly and staying at 195 in all driving conditions... This morning during my drive to work, the low coolant level warning light came on after about 10 minutes of driving... A couple of miles later it turned itself off... I parked the car at work and about 1 hour later popped open the radiator cap... The coolant is only about 1/2 inch below the top of the radiator, clearly above the coolant level sensor... Is this a sign of a gunked up level sensor giving a false reading?
Go Mark Martin!
Old 03-14-2007, 04:15 PM
crazy Jim's Avatar
crazy Jim crazy Jim is offline
when my light started coming on and staying on (even though the fluid level was up) I took the sensor out and cleaned the probe and I also cleaned out the well it sits in, I've had no problems since.
master airframe mech/shadetree auto mech/30+ years experience
current vehicles:
'02 Impala LS 3.8L
'02 Trans Am WS6 LS1 6spd
'99 Grand Am SE 3.4L
'71 Cutlass SX 455/TH400
'04 YZ450F
'07 Kona Garbonzo (dowwnhill mountain bike)
Old 03-14-2007, 07:02 PM
Yeah.... On the drive home the coolant level light came on for about 30 seconds, 10 minutes into the drive, and then turned off again for the rest of the trip home...
What did you use to clean the sensor?... Maybe I don't need to buy a new one...
Go Mark Martin!
Old 03-14-2007, 08:55 PM
crazy Jim's Avatar
nothin special, just clean it
current vehicles:
'02 Impala LS 3.8L
'04 YZ450F
Old 03-14-2007, 09:13 PM
BNaylor's Avatar
Here is the coolant level sensor Bob. Clean the part with that metal sensor (side shown).
Timeslip 08/12/06
