I have a 99 GT. Was doing some P.M.s on it and notice some cracks in my serpentine belt. When should one be replaced and are they a pain to change? Thanks for the help. p.s. It has A 3.8 no S.C.
wiz |
Re: Serpentine Belt Questions 99 GP GT
Depending on how many miles you have on your current drive belt, small cracks in the underside of your belt are acceptable/normal, however, if you're missing two or more adjacent ribs an half an inch or longer or have lengthwise cracks and/or missing pieces, this is "Unacceptable" and should be replaced.
Hope this helps. |
I used a Gatorback belt on mine. One key is get an extension pipe to slide over your ratchet handle to gain more leverage. That will make the job a lot easier, trust me.
97 Grand Prix GT 360,000 miles as of 02-01-09 391 000 miles as of 11-17-11 400,000 miles as of 3-15-13 01 Duramax/Allison 07 G6 convertible |
for replacement its actualy quite easy. like he said use a 15" or so long pipe and put it on the handle of the ratchet because you REALLY gotta crank on it for the install. also to make it easier put it on the main crank pulley(the big one at the bottom) first the work your way up because otherwise its to tight of a squeeze to try and work down there when the belt is that tight
2000 grand prix GTP. CAI, 180 t-stat, u-bend and res delete, custom tuned PCM, shift kit |
