| Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here. |
Oil Leaking From Muffler
I Wanted To Know If Its Bad That Oil Is Leaking From The Muffler And Why Does This Happen Does Anyone Have Any Ideas About Why Or What Can I Do To Solve This Problem i have a 2000 ford mustang regular coupe v6
Re: Oil Leaking From Muffler
1969 Cougar 357w & TKO - 475hp |
ring failure?
valve guides and seals? |
I'm thinking extreme valve seal issues, otherwise it would be hell to start. Bad rings would mean a lack of compression.
leaky headgasket? my sable did the same thing shorly b4 blowing the headgasket rolling over 187k run a compression test see what you find there.
no offense intended but are you sure its not just dirty water condensation from inside the muffler? water will condense in there and turn black obviously from all of the dirt.
07 jeep cherokee srt8 99 saleen s281 05 cbr 1000rr |
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
This is actually a drain hole for condensation in which it mixes with carbon to make it seem to be a oily substance it's H20. The drain hole is normal it keeps the muffler from prematuraly rusting out .
