Old 03-02-2007, 05:13 PM
c62t62 c62t62 is offline
93 parkave driving by itself
today I notice that my 93 park ave was idling very high. If I take my foot off the break from a dead stop, the car will start to accelerate, got up to about 20mph before I put my foot on the break......when I am at a complete stop with my foot on the brake it feels like I have my foot on the break and gas at the same time???????????
Old 03-02-2007, 05:24 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 93 parkave driving by itself
First, check for vacuum leaks, then check the TPS (throttle position sensor) for proper operation. Do a Search Forums for "TPS" (Buick PA or LaSabre) if you need instructions.
Old 03-02-2007, 06:56 PM
Bassasasin Bassasasin is offline
Does this happen when cold or all the time?
HotZ28 gave me a thought.
If you would like you can RELEARN the computer..
Just take off the battery cable for 10 seconds..
If that doesn't help, it' not unusual but it could be mechanical, vacuum leak, dirt in trottle valve area holding it a bit open, etc..
If it does help for a short period of time, it points to sensors and PCM..
A reading of the codes history may reveal something also.
Good Luck
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
Old 03-06-2007, 09:59 AM
seems to be intermitent
Old 03-06-2007, 01:27 PM
This may not help but on a cold start, my park runs up to about 1500rpm and as it runs, oil pressure creeps up and the idle slowly dies down back to about 1100. I drive off about then and about a mile later it's finally hot and all is normal. This process of getting to about 1100 rpm takes about 5 seconds.
With that in mind, during your problem, you may be in a permanent open loop operation. Perhaps the PCM has gotten confused, or a wire is bad.
If you system is stock and there are no vacuum leaks, it may be a MAF, IAT, ECT, sensor. I know you can pull off connectors on some of sensors and troubleshoot some. Disconnecting will throw a code and it would later have to be cleared.
Good Luck
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
