| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
i bought a 99 spyder eclipse and i keep getting one problem after another. I bought it so i could hook it up with some performance parts but its rediculous how many things have gone wrong.(Leaking top,cracked resinator,broken hindge on the convertable top)
and now i got a rubbing noise coming from the pass tire when i turn to the right!does anyone else have these problems or is karma gettin me back?
Re: are the problems ever gonna stop?
If so, that is another common problem that can be fixed in about an hour for about $20. Did you check your wheel well for something catching on the tire? Another thing you have to remember, is that you bought an 8 year old car and probably inherited someone else's problems. It might take a little to get things straightened out, but you will love the car when you do. Is it a GS-T or a GS?
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
DSM = can be unreliable if they were not taken care of, like any other car
spyderturbo007 is right, your inherited an 8 year old car. It is going to have SOME problems, but so far I haven't seen you list any there were hugely critical. Plus, it's a convertible. You should always expect more problems with convertibles.
'92 3000gt SL Zoom Stage 1 Clutch Quote:
welcome to the forums.
As for that bow not going back correctly they sell a kit on ebay for 99 bucks that fixes it. It's great. You could also make something to pull that bow back with like chains (there is a website on it somewhere). To fix the leaky top try these first! Clean it with some soap and water and a scrub brush (lightly!). Clean all the seals and then armor all them. Make sure the latches at the front close tightly. If not you can tighten them up. If the back window leaks and you don't want to replace the top clean it out with a tooth brush in the crack and then put some silicone around the window on teh outside (all the way around). Mine still drips from the corners but it's not bad. I bought a replacement top for 400 bucks but it takes a while to put a new one on. I did one on my old spyder but havn't attempted it for the second time on this new spyder yet.
08 Kawasaki Ninja 250R - Plasma Candy Blue 07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD 97 Mitsu Eclipse Spyder GS-T 5 Speed |
Wheel bearing. If you jack up that corner of the car, put one hand on the top the tire, other hand on the bottom and try to rock it back and forth. If there's movement, its the wheel bearing. Its happened to me before and I ended up just changing the whole wheel hub assembly, I'm on my 3rd one now, lol. Welcome, we could use some estrogen around here
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv ![]() ![]() Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM |
[dirtbag pick-up lines, idiotic attempt to impress, & abuse of power #1] Welcome to AF, stormygirl. I am a *cough* moderator *cough*here. You need anything you let me know. I moderate these forums, so... yeah. I have lots of cars and I'm very cool. So yeah, I moderate around here. Need anything, let me know. Spyders huh...I love Spyders! My ID on here is "Shpyder", what a coincidence! It was meant to beeee! [/end dirtbag pick-up lines, idiotic attempt to impress, & abuse of power #1]
But your problem does sound like the hub though. Go get that fixed or take it to a shop and have them check it out to see what they think. A suspension shop is the best place to go for something like that. They'll know.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
WELCOME TO AF STORMYGIRL!!! opcorn: for wheel bearing...
my bad I didn't realize armor all woudl do that. I do that to my top all the time. perhaps I should stop and just continue with cleaning them regularly.
thanks all for the info im gonna grab the silicone stuff today. I checked out all the tires and discovered that the problem is a cupped tire. Im gonna get an alinement and try to grab some new tires and see how it works out.
It was meant to be funny , hence the [dirtbag pick-up lines, idiotic attempt to impress, & abuse of power #1] HTML tag. Now if we had a MILF surf AF, then I'd be in trouble.Do MILFs even surf forums? Hmmm... I'll have to look into that. |
