Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-02-2007, 11:57 AM
Andrewhuffman Andrewhuffman is offline
speedometer
1998 eclipse rs DOHC 2.0 5spd.
the speedometer dosnt work. all other guages work, i even replaced the speedometer guage, still says 0mph at all speeds. what do i check next? fuse? where does it connect to under the hood?
Old 03-02-2007, 12:03 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: speedometer
Could be the sensor on the tranny. It's under the battery, closer to the firewall. Take that out and replace it. There's little gears on it that may have caused it to go bad.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-03-2007, 08:55 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: speedometer
Check your speedometer fluid, if its not working at all you probably ran 'er bone dry. Only use high grade fluid though, the cheap shit tends to attract lawn gnomes and batman underpants.
^ What Dave said . Please use the subforums homie!
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-05-2007, 07:21 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: speedometer
I think you get the fluid here:
http://kalecoauto.com
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-26-2010, 05:33 PM
tommy bishop tommy bishop is offline
Re: speedometer
i have the same problem switched the sensor and theres fluid ..whats next..help please
Old 02-26-2010, 08:20 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: speedometer
Dude this thread is super old. Dont bring back old threads just make a new one. Could be the gauge cluster, speed sensor, or even the plastic gear that runs the speedo. They can sometimes break and cause the speedo not to work
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
