Old 10-05-2002, 04:52 PM
Fireinthesky28's Avatar
Fireinthesky28 Fireinthesky28 is offline
Send a message via AIM to Fireinthesky28
Question Turbo Vacuum
Yeah....So what is it?
Namely, what could cause such a phenomon, I know about air dynamics, pressure, how a turbocharger works. I just dont understand how pressurized air could lead to air being taken out of the cylinders, how does this happen??
Thanks
So the biblical scholars mis-translated the Hebrew word for "young woman" into the Greek word for "virgin," which was a pretty easy mistake to make, since there is only a subtle difference in the spelling. But back then it was the "virgin" that caught people's attention. It's not every day a virgin conceives and bears a son. So you keep that for a couple of hundred years, and the nexy thing you know, you have the Roman Catholic church.
-Snatch
Old 10-06-2002, 05:14 PM
Anyone?
-Snatch
Old 10-06-2002, 08:07 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Never heard of it. Where did you hear of it?
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 10-06-2002, 09:24 PM
I was lookin through some catalogue, advertising spedometer/tachometer/etc., one of the gauges was a turbo gauge, which was "Equipped to show turbo vacuum", and the gauge started at 20, 10, 0, 10, 20, etc. starting with vac and then moving to boost.
Maybe it is just fabricated, who knows?
-Snatch
Old 10-06-2002, 10:31 PM
I suppose you could see a slight amount of manifold vacuum if you went from idle to WOT suddenly... otherwise that gauge should read above zero most of the time, right?
Old 10-06-2002, 10:32 PM
Yea, that sounds about right...maybe just a waste of plastic and paint
-Snatch
Old 10-07-2002, 12:36 AM
Gasoline Fumes Gasoline Fumes is offline
If that said "equipped to show turbo boost and manifold vacuum," it would make more sense. When the throttle is closed, there will be vacuum in the intake manifold. When the throttle is open and the turbo is making boost, there will be pressure in the intake manifold. The gauge will display both. Don't most boost gauges show manifold vacuum?
My Website
Old 10-07-2002, 01:05 AM
Grendel's Avatar
Grendel Grendel is offline
The gauge (stock) in my car shows both vacuum and boost... all the aftermarket gauges I have seen show the same thing...
-Grendel
Old 10-07-2002, 08:15 AM
that's right... I don't know what I was thinking... if the manifold didn't have vacuum at closed throttle, there'd be no controlling the engine.
Old 10-07-2002, 10:10 AM
Of course...I was thinking cylinder pressure for some odd reason when I originally posted this, but the vacuum in the manifold makes sense...niec.
-Snatch
High quality used vacuum pumps? Sand3 Fabrication Tools 1 02-10-2011 07:59 PM
1997 LeSabre Vacuum Leak? nkmhockey LeSabre 3 12-10-2010 03:20 AM
96 Eclipse Rs Non-turbo Vacuum problem. donidavis Eclipse Problem Diagnosis 27 08-29-2010 09:07 PM
1987 F-250 351w Vacuum Hose Routing Ijustneedhelp F Series 0 07-04-2010 08:23 PM
need vacuum diagram:'88 ram d-50,mitsu 2.0 liter cukoobajube Ram Pickup | Ram SRT10 0 05-31-2009 05:59 AM
