Old 03-01-2007, 04:20 PM
mitsu3kgt mitsu3kgt is offline
aftermarket fpr
Is a aftermarket FPR really worth buying? I had one on my car before and it didn't do much accept help me monitor. I barely used it to adjust the fuel pressure. My friend wants one on his car. He has DSM 13g's and 550cc injectors on his VR4. I don't want to tell him no, because it didn't seem useful to me, but you guys may have another opinion.
Old 03-01-2007, 04:31 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: aftermarket fpr
the car comes with a FPR. why get another one if its working?
now if you were to upgrade your fuel pump, then an ADJUSTABLE FPR would be a good idea so you could maintain the correct fuel pressure. but since you have a stock pump, the stock FPR should be fine.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 03-01-2007, 04:32 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: aftermarket fpr
Be able to adjust the fuel pressure when starting to upgrade is a key factor.
Old 03-01-2007, 05:54 PM
Linebckr49's Avatar
Re: aftermarket fpr
^ i agree. i was trying to distinguish between a simple FPR and an Adjustable FPR.
how much can the fuel pressure be adjusted on the stock fuel pump?
93 3000GT base
Old 03-01-2007, 07:09 PM
Igovert500's Avatar
blue + red light magnet
Re: aftermarket fpr
I think it's a worthwhile mod if you have touched your turbos or injectors. Also even on a stock car it's nice to have it to troubleshoot fuel problems.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-01-2007, 07:32 PM
Stealthee's Avatar
Re: aftermarket fpr
I honestly dont know. can tell you Mine is set to ~42 psi right now and I beleive I am on the stock pump. Last weekend my vac line to the FPR came off and it was hitting ~60psi lol.
