Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-01-2007, 01:54 PM
Bannon7414 Bannon7414 is offline
Send a message via AIM to Bannon7414
Tranny Problems....
I own a 1994 5.7L Caprice with the 4L60E Trans and I only drive it in the spring and summer. I pulled it out the garage for the first time since mid Octobe to drive around for paint estimates on her. While driving I notice that when I accelerate after a total stop it seems like the trans is slipping past first gear and in to 2nd. What could be the potential problem and how can it be fixed? I don't know if rebuilding is an option or if I need an entirely new trans. Any help is appreciated...
1994 Chevy Caprice 350 5.7L Police Package
Old 03-01-2007, 02:02 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Tranny Problems....
How is the condition of the fluid? It could be an indication of wear or internal damage. Methinks it has something to do with the application of the 2-4 servo (2-4 band going into 2nd), could be a leaking seal or a damaged bore.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-01-2007, 02:11 PM
Im not sure on the fluid condition, I will check though. What exactly am I looking for with the fluid? Im not that good with trannys. If this is the problem how can it be fixed?
Old 03-01-2007, 02:24 PM
silicon212's Avatar
Confoundingly Lucid
Well the condition of the fluid will tell a lot about the condition of the transmission overall. What you WANT to see is a clear, red to reddish-orange color with a sweet odor. If you see cloudy, brown, black, murky or strong-smelling oil, that can indicate internal slippage, either in the transmission or in the torque converter. If you're getting a slip (flare) on the 1-2 shift, that could be an indication that the 2-4 band is worn or burned, or that the 2-4 servo (applies the band) is in some way not 100%, or that the line pressure is low.
Old 03-05-2007, 08:13 PM
4evrbad 4evrbad is offline
I had the same thing happen in my trans... had to re-build it It lost first gear initially then about 6 months after the re-build it had trouble getting into 2nd gear, I would have to completly let off the gas for it to shift into 2nd. Luckily it was under warranty. If you plan on keeping the car for awile get a life time warranty or take it to a trusted trans shop. I've seen many 4l60e transmissions go out shortly after a re-build
Old 03-05-2007, 08:14 PM
also now is a perfect time to upgrade your trans or torque converter!
Old 03-05-2007, 11:25 PM
Blue Bowtie's Avatar
Registered Offender
Getting clean oil in the trans is a good idea. While the pan is off, you might want to check the 1-2 shift solenoid valve and coil, and the PWM pressure control solenoid valve and coil. The 1-2 coil should have about 30 ohms resistance, ±10 ohms, and the PWM pressure control coil should be 3-8 ohms.
Along the lines of silicon's advice, you might also want to adapt a pressure gauge and check the line pressure. In DRIVE, the pressure should be at least 55 PSIG, in manual 1st it should be closer to 65 PSIG minimum.
