Old 03-01-2007, 01:40 PM
Zonda's Avatar
Zonda Zonda is offline
Question Removing paint from a Spark model. Help!
Hi,
I'm planning to repaint a Spark model. The models is made of white plastic resin, different from the one S.A.S. and BBR uses. What can I use to strip off the paint? As I don't want to melt it and be left with nothing. Is brake fluid okay? Or a no no?
Cheers!
Old 03-01-2007, 06:44 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: Removing paint from a Spark model. Help!
No! I don't know what to use. Just not brake fluid. I will now sit quietly and wait for a response, as well.
Old 03-01-2007, 06:50 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
a nice bath in rubbing alcohol, 90%+ iso, should do the trick. though im not sure if they use a catylized finish or not but this is safe for the body and worth a shot.
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
Old 03-02-2007, 12:17 PM
Zonda's Avatar
So brake fluid is out of the question in any case? I'll give the alcohol a shot. I have no idea if they have used catylized finish on the body. With catylized finish... acohol wont work then? Thanks!
Old 03-03-2007, 03:05 AM
sjelic's Avatar
sjelic sjelic is offline
Owen cleaner usualy do the trick, with my last model I was so brave to even try Nitro thiner on resin, It worked with no problems, I took wide pan poored Nitro thiner inside, took big brush and brushed the paint of the resin, paint was relatively fresh so it went of with no problem.
Please don't try this without test because nitro is extremly hot.
Sasa Jelic
SCALEMAKERS
Old 03-03-2007, 06:01 AM
Lambo003's Avatar
Lambo003 Lambo003 is offline
You may want to try a nice long soak in Pine-Sol (or it's equivalent) or Wesley's tire bleach followed up by a light cleaning with paint thinner (used sparingly with a stiff brush) to get in the crevasses . . .
I've stripped several factory painted resin models this way for fear of ruining the body. . .
Chuck
Old 03-03-2007, 01:08 PM
Zonda's Avatar
Thank you guys for the reply. I will have to try those out and see which one will have the best result. Wish me luck!
Cheers!
