Old 03-01-2007, 01:15 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
Code 3 on d15b swap?
91 crx si D15b vtec swap Utilizing crx intake manifold and throttle body. P08 ecu.
I'm getting a MAP sensor code. any suggestions? Does it ave to do with the fact that the d15b vtec map sensor is supposed to be on the throttle body and im still runniing the crx MAP?
Old 03-01-2007, 02:19 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Code 3 on d15b swap?
Well, no. not neccesarily the locations, but the ecu maybe be looking for different map voltages than yours is putting out. But it shouldnt really matter as long as your map is attached to a vacuum line on the intake manifold. You COULD have a vacuum leak. Do you have idle issues? like a surging idle? I would make sure that ALL of your lines are air tight, and that your gaskets are good.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-02-2007, 10:17 PM
You rock, yes i had a loose line! I love this swap. Its finally perfect! Time for suspension!
Old 03-02-2007, 11:15 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
glad to hear all turned out well.
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
