Old 03-01-2007, 01:12 PM
[email protected] moez1010@yahoo.com is offline
Need some smarts
Dad said if manual fails find some smarts.
86 Caravan. Had elecric fire due to short in starter. Burned cable for hood so much worse. Had to pry hood up to cut battery supply. Got harness and started splicing. Eliminated A/C circuit altogether Blue?org and Black/org (i'm thinking power windows) But Van satrs up and runs to warm they sputters and dies. Im thinking spark is not advancing. Could PCM fryed in the the short
and not telling the dist to advance?
Old 03-02-2007, 07:49 AM
jsinton jsinton is offline
Question Re: Need some smarts
Could be ECU, but are you sure you want to try to fix it anymore? Sounds like it's going to have infinite problems now. Anyway, possible causes could be:
Bad connections at distributor, coil, or alternator.
General fault in fuel or electrical system (infinite possibilities)
Vacuum leak on the intake side.
Insufficient fuel pressure.
Old 03-02-2007, 02:24 PM
Bernard Feltzer Bernard Feltzer is offline
Why don't you take the van apart, then rebuild it ?
It can be done, we have the technology...............
Old 03-03-2007, 12:06 AM
Location of ECU 86 caravan? 2.6 Thanks for the help already.
Appreciate the help and the humor. Keep it coming.
Bernard you help me fix my van and I'll laugh at your jokes Ok?
