Old 10-05-2002, 12:26 PM
ukemaxxer's Avatar
ukemaxxer ukemaxxer is offline
Busted A pillar
Help
I have a Tamiya Skyline kit with a broken A pillar.
What do you think would be the best way to repair it?
Old 10-05-2002, 12:55 PM
COZMO6476's Avatar
COZMO6476 COZMO6476 is offline
that sucks... but its happened to me a couple times already... i just glue the pillar back together with plastic cement and very very carefully sanded it smooth. then i was very very careful not to break it again. you cant really put a reinforcment behind the pillar since it usually buts up against the clear plastic of the windows so you dont have many options. good luck. id like to see what others have done
Old 10-05-2002, 12:57 PM
turbos86's Avatar
turbos86 turbos86 is offline
Gluing is what I do too. Both A pillar snapped on me for my Civic, and they are fine now all painted up.
Old 10-05-2002, 01:16 PM
Daryl's Avatar
Daryl Daryl is offline
I glue the joint, putty it up just a little, then sand smooth. Putty seems to add a bit of strength... at least that works for me.
Left is right. Right is wrong.
Old 10-05-2002, 01:54 PM
ukemaxxer's Avatar
Thanks guys, Ill give it a try and see how it ends up
Old 10-05-2002, 04:10 PM
935k3's Avatar
935k3 935k3 is offline
That car's shape makes that area vunerable. The racing verion(Calsonic group A touring)is the only car I ever got from Tamiya that had a warped body. You might want to re-enforce the pillar by super gluing a very thin strip of soda can aluminum to the back of it. if you cover the window unit with tape and tape it into the body when you are polishing or sanding the body it would give you some support.
Please Help! Completely busted cigarette lighter georgk General Discussion 1 03-17-2011 11:16 PM
How to get A Pillar off to install Lo Tek Pillar Pod urmystlkal Off-Topic 10 04-26-2004 02:10 PM
Autometer full A-Pillar dual gauge pod FS toolowintegra Canada 0 02-05-2002 09:21 PM
Pillar Gauge Pods rOaD bEaSt Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 09-20-2001 01:24 AM
pillar gauges jcl603 Cosmetics 8 06-14-2001 07:36 AM
