Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-27-2007, 10:33 PM
zenit27 zenit27 is offline
Faulty dashboard lighting
It all starter by the turning signals getting on when i turn on the lights and if the lights were off and step on the brakes the dashboards light will come on, and tonight all the dashboard went dark. Any ideas of possible cause. Any help will be appreciated. Thanks!
Old 02-28-2007, 11:25 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: Faulty dashboard lighting
Year and model?
Could be a number of things. These trucks do weird things when there is a problem (even minor) electricly.
1. Bad ground connection. Check them all.
2. Bad trailer wiring harness if installed. If you have one try disconnecting it.
3. Brake light bulb or socket with bad connection.
4. Bad/corroded battery terminals.
5. Alternator failing.
Those are the most common.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
