Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 02-27-2007, 09:11 PM
Roger0021062 Roger0021062 is offline
1996 skylark a/c question
I just bought a 96 skylark and the a/c blows warm.I purchased two cans of R-134 and have the hose with a gauge showing freon status as low,ok,or overcharged.I have looked all over this car and cannot fiqure where to add it.I have done this many times before on other cars so it's nothing new to me but cannot locate correct port.I have one fitting right behind radiator that is too large for the hose I have and it has a red cap on it.And I have one that says evaporator service port that is to small for the hose i have .My hose has a quick coupling end on it but i'm having no luck.Thanks for any help,Roger
Old 03-01-2007, 10:46 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1996 skylark a/c question
The low pressure port to add refrigerant is probably located on the backside or vicinity of the compressor. Hard to see from above and you will need to look from underneath the car.
Here is a pic with the compressor removed (blue cap).
Timeslip 08/12/06
AF Community Guidelines
Old 03-01-2007, 02:57 PM
Thumbs up Re: 1996 skylark a/c question
[quote=bnaylor]The low pressure port to add refrigerant is probably located on the backside or vicinity of the compressor. Hard to see from above and you will need to look from underneath the car.
Thank you very much your a life saver.Roger
Old 03-02-2007, 08:55 AM
BNaylor's Avatar
You're welcome and let us know how it turns out. Good luck.
Timeslip 08/12/06
