Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 02-27-2007, 08:35 PM
daniel21 daniel21 is offline
1998 Continental Headlight Adjustment
Can anyone tell me how to adjust the headlights on a 1998 Continental? Any help would be greatly appreciated.
Old 03-01-2007, 05:40 PM
Towncar's Avatar
Towncar Towncar is offline
Re: 1998 Continental Headlight Adjustment
Here's some bad news, see note one regarding Horizontal aiming
Headlamp Adjustment — Screen Method Aiming
Note 1:
Horizontal aim is not necessary for this vehicle and is not adjustable.
Note:
Consult your state's vehicle inspection manual for recommended tolerance ranges for visual aiming.
1. Note:
The sight shield may need to be positioned or removed for access to the adjusters.
Before starting headlamp assembly adjustment:
  • Check the tire inflation.
  • Check that no other load is in the vehicle other than a half tank of gas.
  • Check that the headlamps are clean.
  • Check for correct headlamp operation.
  • Check that the vehicle is on level ground.
  • If the vehicle is equipped with air suspension, make sure the switch is on.
2. Note:
The vertical wall or screen must be a minimum of 2.4 meters (8 feet) wide.
Park the vehicle on a level surface approximately 7.6 meters (25 feet) from the vertical wall or screen directly in front of it.
3. Note:
The center of the lamp is marked by a 3 mm (0.12 in) circle on the headlamp lens.
Mark a horizontal reference line on the vertical wall or screen.
1 Measure the center of the headlamp height to ground and record.
2 Make a 2.4 meters (8 feet) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
4. Note:
This procedure should be done in a dark environment to effectively see the headlamp beam pattern.
Turn on the low beam headlamps to illuminate the wall or screen and open the hood.
5. Note:
The appearance of the beam pattern may vary between vehicles.
On the wall or screen, locate the high intensity area of the beam pattern.
6. Note:
Identify at the top edge of this high intensity area a distinct horizontal cutoff in the beam pattern. If the top edge of this cutoff is not even with the horizontal reference line, the headlamp beam will need to be adjusted.
-Steven
1996 Town Car, Cartier
Old 03-01-2007, 09:01 PM
Towncar,
Thanks for the info. Can you tell me where the adjustment screws are located? By screws, I mean the one adjustment screw for each of the headlights.
Once again, thanks for the help.
Old 03-01-2007, 11:43 PM
Towncar's Avatar
Towncar,
I have no idea what the Sight Shield is on this car, but it says the sight shield may have to be moved in order to see the adjusters.
-Steven
Old 03-31-2007, 10:57 PM
cougar214 cougar214 is offline
Im not sure but i think its refering to that big plastic cover across the nose of the car daniel.....you know the one that covers the radiator and such to make the engine compartment look pretty.
