Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-27-2007, 07:26 PM
1988capriceclassic 1988capriceclassic is offline
Tail Lights
OK I HAVE A 88 CAPRICE AND THE TAIL LIGHTS HAVE A LITTLE PROBLEM THEY TURN ON AND TURN OFF WHEN THEY WANT TO I CHECKED THE FUSE AND ITS GOOD I KNOW IT HAS SOMETHING TO DO WITH THE WIRES BUT I WANTED TO CHECK IF ANY ONE ELSE HAS HAD THIS PROBLEM BEFORE I TAKE IT TO THE SHOP
Old 02-27-2007, 07:41 PM
mike561 mike561 is offline
Re: Tail Lights
first thing i would do is check the connection point on the bottom left side under the trunk carpet, theres a little ditch under the carpet and a connection for all your rear lights.
2006 Chevy Cobalt LS
Old 02-27-2007, 07:58 PM
Re: Tail Lights
I Checked That Out And It Seems Ok I Noticed That Every Thing Works Good The Brake Lights Turn Signals And Head Lights Even The Cluster Light I Think It Might Be The Switch But Im Not Sure
Old 02-27-2007, 07:59 PM
GreyGoose006 GreyGoose006 is offline
Re: Tail Lights
wait, whats the problem?
are they not working properly?
one of the bulbs is probably burnt out if the turn signal doesnt work on one side only
Old 02-27-2007, 08:00 PM
Re: Tail Lights
use punctuation please, i cannot understand what you are saying.
Old 02-27-2007, 08:22 PM
Re: Tail Lights
Every Thing Works Properly Turn Signals,head Lights,brake Lights,cluster Except The Parking Lights On The Back The Front Ones Work Properly,so I Was Thinking It Might Be The Switch But Im Not Sure.
Old 02-27-2007, 10:02 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Tail Lights
Please Do Not Capitalize Every Word You Type. It Is Very Distracting And I Am Sure That Nobody Will Want To Help You If They Can't Follow Or Are Distracted By What You Type.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-28-2007, 11:54 AM
Re: Tail Lights
ok... is the problem with your rear parking lights?
i dont think that they are on any other time except when you have the headlight switch pulled half way out.
check the bulbs first.
another thing to check is your taillight assembly.
if one of the bulbs is out in your taillight assembly, you may not realize it because the bulbs are dual filament. if one of the filaments is gone, the bulb will still work, but not correctly, and it will cause the other bulbs to not work right.
it is also possible that the parking lights you are having problems with are in wrong, or you are using the wrong bulbs.
you could replace the switch too, but i'd check everything else first.
it seems to me (although i'm no expert on electronics) that if the switch was bad, the front parking lights would be out as well as the rear ones.
