Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 02-27-2007, 04:40 PM
Treblig70 Treblig70 is offline
Need Some Help Here!
99 Tahoe 2WD, auto, 4.7 (old style). Had low fuel pressure (50 PSI). Replaced fuel pump and filter, now I have 54 PSI. Everyone says I need at least 60 PSI. Can I change or adjust the regulator to increase pressure??? Can I make an in-line (at fuel filter) pressure check to verify my new pump is putting out good pressure. I don't know whether to remove the intake to replace/adjust the regulator or drop the tank and replace the new pump again (it's still under warantee). Gil in Tex
Old 02-27-2007, 07:34 PM
777stickman 777stickman is offline
Re: Need Some Help Here!
The GM service manual says 55-60 psi. You're at 54. Unless you're having drivability problems I wouldn't worry about it. Maybe try a different pressure guage and compare???................Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-01-2007, 05:49 PM
My Tahoe is clattering (valves) under load. I replaced the fuel pump because the pressure was at 50 PSI. Most everyone on this forum (including Merlin)says I should have at least 60 and that 64 is preferable. The new pump gave me 54 PSI (still too low). I just need to know if I can get a better reading at the fuel filter and if the regulator can raise the pressure to 60????Gil in Tex
