2001 Buick Century - Oil leak
I took my car in for an oil change over the weekend. On the comments section of my bill, the technician wrote "oil leaking". What could be causing this? I hope it's not something too expensive to fix.
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."– Theodore Seuss Giesel |
Re: 2001 Buick Century - Oil leak
Oil leaks result from one thing and one thing only, gasket failure.
the question is, which one. |
could be you need a new oil plug also..he never told you where or showed you where the leak is?
If you can get it on a lift and look underneth, you might be able to find it.
1994 Honda Civic - D15B7 W/5 spd 2000 Olds Intrigue - 3.5 Cory |
He never told me where the leak was nor showed me. Being the woman that I am, after waiting all day (it seemed like) for an oil change. I paid the bill and looked at it later. Would one of those diagnostic tests tell me where the leak is exactly?
nono, diagnostic "testing" involves faults in the powertrain control module that elmuinate the check engine light to notify a problem and that the engine is not performing as designed.
A oil leak is found only by good old fashion "let's take a looksy where it's coming from" that has been around since the inception of the motor. Is the car leaving noticable spots in your places of common parking? |
There are no oil spots in my garage. Not even a drop. Sometimes, not very often, I'll see what appears to be water underneath my car. That only happened over the summer though. No water spots this winter.
Since it is not leaving spots, it is not a 'major' leak, and thus, I would say on your next oil change, bring the receipt in and ask the service rep to have the technician verify the noted leak and explain. It could something as simple as the drain plug gasket. |
ok will do. Thanks for all your help. I appreciate it.
