Old 02-27-2007, 09:46 AM
speak1104 speak1104 is offline
'94 Plymouth Voyager steering column removal
I am attempting to replace my ignition switch. Im having a problem removing the steering wheel and column cover. Any how-to's?
Old 02-28-2007, 02:50 AM
Bernard Feltzer Bernard Feltzer is offline
Re: '94 Plymouth Voyager steering column removal
I used a pulley remover to remove a steering wheel, popped right off.
Mine didn't have an airbag, so don't blow it up.
Old 03-11-2007, 12:45 PM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
You don't need to remove the steering wheel to replace the ignition switch on a 94 Voyager. Remove both upper & lower covers behind the steering wheel & you will have access to the ignition switch (3, 20 torx tamperproof screws hold it in)
