Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 02-26-2007, 09:44 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
LS1 injectors in TPI???
can i put the stock ls1 injectors into a tpi setup and it will all work and fit right? thanks-Tom
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 02-27-2007, 01:34 AM
Morley Morley is offline
Re: LS1 injectors in TPI???
You sure can. I have 2 TPI cars running LS1 injectors now. The only thing is that at 43.5psi those injectors are 25#/hr. But for me that isn't a problem since I burn my own custom chips
Old 02-27-2007, 09:34 AM
so i would have to get it tuned if i got them
crane cam cam specs
MY VIDEOS
MY PICTURES
-Tom
Old 02-28-2007, 02:27 PM
Yes! Especially if you are running the 400 sbc in your sig. You should already be running a custom chip with the 400 and cam.
Old 02-28-2007, 05:10 PM
well im actually working on another 85 vette and the injectors ar about to take a shit, (183000 miles) and i saw the ls1 low mileage tako offs on tgo for 50 bucks and was thinking about buying them for the mostly stock vette. and yeah my sigs old, gotta change it. im carbed now
crane cam cam specs
MY VIDEOS
MY PICTURES
-Tom
Old 02-28-2007, 06:47 PM
In that case, no, you won't need to reprogram the ECM for the new injectors. In 1985 the Corvette used 24# injectors and the LS1's are 25#. not enough of a difference to affect it. Also, the 85 Vette used the 870 ECM, 1985 TPI's were the only ones to use the 870 along with the MAS module. The 870 is a very different ECM than the later ones (86-92 TPI), the programming isn't as easy as the later ones and there are things you can't do with them because a lot of the programming is hardwired onto the ECM's main board.
