Old 02-26-2007, 07:39 PM
hughes1059's Avatar
hughes1059 hughes1059 is offline
Send a message via AIM to hughes1059
what sensor is this???
my truck recently overheated like crazy... after gettin her home and inspecting the damage... i noticed an electrical socket with the connecting end of a sensor that had been burnt off... after looking in the area the wire runs too... i unscrewed what looks exactly like a coolant temp sensor, only thing is is that it was mounted on the block... and not the manifold like ECTS's usually are... and after reading the manual i found the ACTUAL temp sensor in the manifold right where it says it should be/// now i dont know wtf this sensor is... def not oil pressure, or knock either!!!!!
its a 94 W motor 4.3 and the sensor is in between the first and second spark plugs on the passenger side of the motor
HELP!!!!
Opie
Erie, PA
Old 02-26-2007, 09:50 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: what sensor is this???
There are two coolant temperature sensors, one for the computer and one on the other side for the dash temp gauge.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-27-2007, 09:48 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As BlazerLT said there are 2 coolant sensors.
One pcm and one dash gauges/light.
The one between the spark plugs is for the dash gauges/light.
MT
