Old 02-26-2007, 08:00 PM
DjDio DjDio is offline
Cool Fuse box's
I just bought a '93 LeSabre Custom and it did'nt come with a manual. Does anyone know where i can get something that tells me what fuse is what? Besides going out to buy a manual. Maybe a picture of the fuse box covers or something?
Old 02-26-2007, 08:41 PM
Bassasasin Bassasasin is offline
Re: Fuse box's
Which fuse group. .Under hood or IP?
1. – 10 amp . Instrument Panel Lights
4. - 10 amp Ignition, Radio
5. – 25 Amp Windshield Wiper & Washer
6. – 10 Amp Cooling Fan, Transmission
7. - 25 Amp Air Conditioning
8. – 10 Amp Heated Windshield
9. – 10 Amp Anti-Lock Brake System
10. – 10 Amp Low Coolant, Light Monitor Oil Level, HUD/Compass Amp L
11. – 15 Amp Battery, Radio Instrument Panel, Oil Level
12. – 20 Amp Electronic Level Control
13. – 20 Amp Brake & Hazard Warning Lights
14. – 14 Amp Parking Lights
15. - 15 Amp Courtesy Lights & Power Mirrors
16. - 15 Amp Ignition, Retained Accessory Control, Instrument Cluster
17. – 10 Amp Supplemental Inflatable Restraint
18. – 20 Amp Cornering Lights, Turn Signals, Back-Up Lights
19. -
20.
21. – 10 Amp Start Up Signal, SIR
22. - 20 Amp Trunk Release, Back-Up Lights, Trunk Release
23. – 30 Amp Power Window, Sun Roof
24. - 30 Amp Power Accessory
25. – 10 Amp Heated Mirrors, Compass
Keep em' Drivin'
Bass
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
Old 02-26-2007, 08:45 PM
Re: Fuse box's
Fuse boxes under the dash. There is one on drivers side and also one on passenger side.
Old 02-27-2007, 01:23 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Fuse box's
Bass listed the driver side fuses for you. The passenger side fuses and relays are listed on a label which should be attached to the passenger side sound insulator. BTW, you can pick up the fuse panel cover with the label that you're missing real cheap at most boneyards.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 02-27-2007, 11:25 AM
Smile Re: Fuse box's
Thanks alot bassasasin. The passenger side sound insulator doesnt have the list anywhere. I realize i can pick one up at the boneyard but money is tight and the nearest boneyard is an hour drive. Thats why i asked in here. Thanks again.
Old 02-27-2007, 11:57 AM
Loekee75's Avatar
Re: Fuse box's
DjDio, I'll check out the fuse label in my father's '93 LeSabre Custom, I'll note the order and relist them on here like Bass did the driver side labels. I do know your horn relay, power locks fuse, rear defogger relay, electronic level control relay, and interior lights relay are under there.
Old 03-08-2007, 02:43 AM
Loekee75's Avatar
Re: Fuse box's
DjDio, these fuses and relays were labeled in my dad's '93 LeSabre Custom, so they should be the same for your car. Other years, models, and Limited models may differ:
Fuses, listed from the very top on down, left row:
15 AMP- ERLS MISC ENG CONT
20 AMP- FUEL PUMP
10 AMP- FUEL INJECTORS
10 AMP- ECM
Fuses, listed top to bottom, second row:
10 AMP- A/C PROGRAMMER
*BLANK"
15 AMPS- PWR ANT, DOOR LOCKS
20 AMP- HORN
Relays, listed left to right, top row:
*BLANK*, REMOTE TRUNK RELEASE, REAR DEFOG, DR. DOOR UNLOCK
Bottom row, listed left to right:
COURTESY LIGHTS, ELC, FUEL PUMP, *BLANK*
Old 03-08-2007, 07:26 PM
Re: Fuse box's
Thanks you very much Loekee. I appreciate this.
