Old 10-04-2002, 09:29 PM
ruffman ruffman is offline
Angry its dead......
well that was that after 4 hard weeks of work, my Lexus has died, the culprit, shitty design on its wheels no matter how hard I tried they would not go onto the wheels
they would not even turn after assembly.....not meant to...so all the trying resulted in a crushed passenger side strut and plastic axle, and a severley bent rear strut...so all the parts when back into the box and into a closet...I will probably use the body to practice painting and polishing....what a piece of shit the AMT wheel system is, all of the parts where so flimsy...:rocket: :greenchai :monkeypis
Old 10-04-2002, 10:48 PM
tonioseven's Avatar
Unhappy Sorry dude!
Bummer
Old 10-04-2002, 11:03 PM
Murco's Avatar
Murco Murco is offline
Maximum Car Guy
Send a message via Yahoo to Murco
Your giving up way too soon!! It's a plastic model! Didn't you notice it was all "broken" when you started?? Fix the struts and put that car together!!
My AF Classic Model Car Gallery
Old 10-04-2002, 11:56 PM
turbos86's Avatar
turbos86 turbos86 is offline
Murco is right
See these?
These suspension were snapped into a million pieces and melted on a candle flame, but I still put it back together! If I can do it, you can too!
Old 10-05-2002, 12:41 AM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
well....you have 2 options. Get it out of your closet and put it together
or
get it out of the closet and mail it to me.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 10-05-2002, 12:46 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
Get some superglue, and glue it together (with or without suspension)
It would look good with out suspension....sooooo looooow
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 10-05-2002, 12:48 AM
Jonno's Avatar
Turbos86: Is that thing, that looks like it is made of wood, the exhaust?
Old 10-05-2002, 02:19 AM
turbos86's Avatar
It's suppose to look like a brass color, oh well~
Old 10-05-2002, 02:53 AM
Alright u gave me hope....a little....i went to the closet and pulled it out...i tore off the rear suspension...fixed it and glued it back together...it looks pretty good and i got the tires on so we will see....the front is a different story...everything was torn off and the struts pushed into the wheels with alot of force, they went in one is not on so well....the whole paint job is messed up, i will have to brush paint touch it up...and the front drive assembly will have to be glued with the car turning to the right no straight driving for this Lexus......
Old 10-05-2002, 06:09 AM
primera man's Avatar
"P-Man"
Good to see you are not giving up
The old saying is "we learn by are mistakes".....i'm sure you will be better off in the long term
View All My Models Here.
Old 10-05-2002, 06:51 AM
Jonno's Avatar
You should chrome it.
Looking at it from the first picture, it looks like brass, but the second picture looks like wood, maybe because it has those lines in the direction of the grain in a piece of wood. And theres the bumps in it.
What kit is that?
Old 10-05-2002, 07:26 AM
935k3's Avatar
935k3 935k3 is offline
Hopefully you lkearned a good lesson from all this. Test fit every thing before any paint ing is done. Wheels and ride height should always be checked and corrected ahead of time. Glue the suspensin together with white glue and see how it sits. Strut type suspension is easy to make and fix. Just use some aluminum tubing for the upright part of strut. I have even had to modify a few Tamiya kits to get them to sit right. I don't trust any thing straight out of the box.
Old 10-05-2002, 02:09 PM
turbos86's Avatar
ruffman: Glad you're not giving up. If the front suspension is really unrepairable, take some styrene sheets and rods and remake it.
What kit is that?
That's a S2000. I guess cause I brush painted it that got it looking like wood. It's suppose to look used and heated, so Chrome would be wrong.
Old 10-05-2002, 02:27 PM
daggerlee's Avatar
Painting it solid bronze, then spraying it with X-19 smoke/X-26/27 clear red/orange or clear yellow/blue might give better results
Dan
Old 10-05-2002, 02:48 PM
Wishmaster's Avatar
Wishmaster Wishmaster is offline
***** Lurker
YOu said it was an AMT kit, they are known for their bad fitting, so if it doesn't work for you, try a Tamiya or Aoshima kit, they should fit much better.
Painting still is something you'll have to master, just like me but it'll worked out very well.
Greetz
Stefan
01 Kia Sportage 4x4 DEAD No start No power Needs jumpstart everytime HPYUNBDAY Sportage 2 07-27-2011 09:45 PM
Lost Key AND Dead Battery! db99 Town Car 7 06-09-2010 11:25 PM
91 Camaro ran fine and now its dead...need help DrunkenMcGee F-Body Problem Diagnosis 9 01-27-2008 11:17 PM
its dead 22whiteknight Escort 1 01-20-2004 01:58 AM
