Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 02-26-2007, 04:33 PM
Truck Truck is offline
My 2.5 Cyl Corolla
I have an 89 Corolla, 4-AF engine and it is missing horribly. I have checked the mechanical parts of the head, and it seems to be in fine condidtion. ( I have not removed the head to see what the block/piston situation is.)
My question is, could there be an electrical problem that is causing it to miss so bad? When the motor is running, I can pull the #2 and #4 plug wire(s) and there is no difference in the engine note, (which is horrible.) Should I look at replacing the distributor? I've already replaced the cap/wires.
Old 02-27-2007, 01:55 AM
KimMG KimMG is offline
AF - Advisor
Re: My 2.5 Cyl Corolla
Have you done a compression test? Do you get spark at the #2 and #4 spark plug?
Old 02-27-2007, 06:35 AM
Weak Spark...Low Compression.
Old 02-27-2007, 12:20 PM
AF - Advisor
Have you done a wet compression test? If yes, were the readings higher?
Weak spark can be caused by bad spark plug wires, cap, or rotor.
