Old 02-26-2007, 01:29 PM
PlayStation3 PlayStation3 is offline
impedence question.
hi, i was looking at infinity kappa ( 2 ohm) and i was was wondering that would make it a 2 ohm load to each channel if 1 is wired to each channel right ( yea i know dumb question)
Old 02-26-2007, 03:21 PM
BlasZ24 BlasZ24 is offline
Re: impedence question.
That would be correct.
Old 02-26-2007, 06:54 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
So a 2 channel amp, and 2 infinity kappa 2ohms one on each channel yes that would be right. Same concept on a DVC.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 03-03-2007, 09:24 PM
dbfreak147.5 dbfreak147.5 is offline
is the sub dual voice coil, if it is the only options you can get out of one is 1 or 4 ohm, if there are two of them you can get .5,2,8 ohm
2 Orion HCCA 10'S
2 AudioPipe 3k's
Adam Whitehead
Old 03-03-2007, 11:34 PM
Or you can get a 4 channel amp and wire each coil to one channel. you dont have to always use a mono amp for subs, its not always the best in some cases you can draw less current and not make the amp work as hard wiring stuff up in bridged 4 ohm on a 2 channel amp.
Cardomain
Old 03-04-2007, 01:46 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
mono amps may not always be the best, but class D are a lot more efficient and they are mostly monobloc amps
Old 03-04-2007, 02:02 PM
^^^ once again thank you paul
2 Orion HCCA 10'S
2 AudioPipe 3k's
Adam Whitehead
Old 03-04-2007, 02:50 PM
But you also dont alwasy need the most efficient amp, obviously you would want a class d if your going to be running 1k watts or more, but in most cases like mine where i only need 300 for each sub, im not going to worry about the efficiency of the amp. There are a lot of possibilites for wiring to diffrent loads for different amps, he could use a mono amp thats stable to 1ohm, a 2channel amp thats stable to 4ohm bridged or a 2 channel or 4 channe amp that has each channel capable of handling 2 ohms. Of course you dont have to worry as much about matching gains if you use a mono amp or a 2-channel compared to a 4 channel. BUt in this case a 4 channel amp that puts out 150rms @ 2 ohm would put that to each coil for either 2 or 4 subs. Theres alot of options when doing any of this.
Cardomain
Old 03-04-2007, 03:05 PM
actully i think i have found my next amp. it's a soundstream
Old 03-04-2007, 03:22 PM
Ive heard there amps are pretty good, cant say ive heard the same about there subs.
Cardomain
Old 03-04-2007, 04:22 PM
i had a soundstream xxx 15, i hit a 147.9 on the dash @ 34 hz on the new tl with a RE35.1 amp
2 Orion HCCA 10'S
2 AudioPipe 3k's
Adam Whitehead
Old 03-04-2007, 05:29 PM
Audio Guy
I try to educate you guys, make you think a little. I think an informed consumer makes much better choices, it makes good comapnies shines and shady ones, well ......
Old 03-04-2007, 10:13 PM
what are you trying to say paul . i finally i'm not looking totally mainstream. here is a link to it. http://www.onlinecarstereo.com/CarAu...roductID=15528
Old 03-05-2007, 05:33 AM
Audio Guy
I am saying if people stay away from "flea market" brands, they might start to disappear. Even the cheaper brands must have some type of quality standards to survive.
Old 03-05-2007, 10:05 AM
is soundstream a flea market brand?
i thought stormstream or something like that is
