Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 02-26-2007, 12:16 PM
metolious69 metolious69 is offline
'00 Tahoe Keyless Remote
I believe my battery is going dead in my keyless remote. Will I have to reprogram the remote when I replace the battery or will it be OK? I have the reprogramming procedure just in case. Also, where can I find a replacement battery...I haven't seen them in many auto shops.
Thanks for your help.
Old 02-26-2007, 01:38 PM
greengumby greengumby is offline
Re: '00 Tahoe Keyless Remote
there easy to find what they are is a watch battery. you can get them at target , walmart , cvs just about anywhere. once you open the remote there will be a number example 2025 take that number and look up the watch battery . Chances are you do not need to reprogram the remote unless your adding a new unit . I never had to reprogram my remotes when they went bad on my 04
Old 02-26-2007, 06:37 PM
Thanks, I'll give the watch battery a try.
Old 03-03-2007, 09:22 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Most remotes say this inside, but after you get a replacement CR2032 battery just install it and put the remote back together. Now go up near the truck and hold down LOCK & UNLOCK on the remote for 7 seconds to re-sync the remote.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
