Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 02-26-2007, 09:20 AM
primal1 primal1 is offline
99 tahoe wont start
it starts off cranking like its going to fire, but then the cranking slows down for a second. while the cranking slows, the voltage drops to about 10. then it cranks normal for a couple of cycles, then gets drawn down. and repeats. it stutters while cranking. could it be a starter malfunction. when the massive draw comes on, there is not enough spark to ignite the fuel? i hooked it up to a jump starter with 200 amp capacity. even with that there was the lobe during the crank cycle.
Old 02-26-2007, 03:36 PM
maxwedge maxwedge is offline
A990 racer
Re: 99 tahoe wont start
I'd check fuel ressure 60-65 psi needed, then look for bad battery connections for the erratic cranking issue.
Old 02-27-2007, 08:48 AM
60 psi. battery connectioins seem good. i went through in nov. and got rid of the double stack pos battery connectors and converted to 1 to eliminate the corrosion problem.
Old 02-27-2007, 12:54 PM
i hooked up a inline spark tester with the #4 plug. getting spark. pulled off the cap and rotor replaced rotor and cleaned cap. sprayed ignition drying agent inside of distributor. still nothing.
Old 02-27-2007, 02:15 PM
jnicks01 jnicks01 is offline
I'm having the exact same problem. I was told it could be the fuel pressure regulator (you seem to have good pressure though), Fuel pump (I had one replaced 2 years ago), or the theft system. I'm taking mine in soon to get looked at, so I will let you know what I find out. Please keep me informed too of anything you hear.
Old 02-27-2007, 02:27 PM
i was under the impression that if it is the theft system, you should get the security light. i'm not. i know mine is not the fuel pump because its getting 60 psi to the valve on the intake. the regulator is a possabilty becuase its in the intake from what i understand.
Old 02-27-2007, 05:41 PM
pulled the plugs #4,#1, and #3. all were wet with fuel. i think that eleviates the chance of csfi system being clogged.
Old 03-01-2007, 08:09 PM
turned out to be a hairline crack in the cap.
