Old 02-26-2007, 08:37 AM
102phil 102phil is offline
93 voyager rear wiper problem
I have a 93 plymouth voyager but I am having problems with the rear wiper it has been this way since I purchased it. It is stuck in the upright position and I don't have a clue how to fix it to make it work again or to even get it to lay down and not block the rear window. Can anyone help with this fix?
Old 02-27-2007, 10:21 PM
sixseas's Avatar
sixseas sixseas is offline
Re: 93 voyager rear wiper problem
I had a similar problem with my 93 T&C. Be careful not to force use firm gentile pressure because you may damage the wiper cam that turns the shaft the wiper is mounted on. My guess is either you have a corrosion or something binding the mechanism that turns the wiper, wiper shaft is frozen or motor is frozen. First I checked the fuses then took off the rear panel on the back door. I made sure the mechanism that turns the wiper was free. I unplugged the motor turned rear wiper on and checked for 12 vdc at the plug. In my case the power was there so I replaced the motor and has worked fine for years. It’s a relatively simple job easy to get to and I would think a used motor would cost only a couple dollars at a bone yard, I would guess many different years rear wiper motor would work but best to check for sure.
Old 07-29-2009, 06:18 PM
kieldsing kieldsing is offline
How do I get the panel off the rear liftgate of the 93 Voyager to get to the windshield wiper to replace it. I removed all of the screws and popped the outside pins but the panel would not release where the window and door meet each other. I could not see any more screws or pins to remove.
