Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 09-06-2001, 10:35 AM
redvalkrie's Avatar
redvalkrie redvalkrie is offline
Send a message via Yahoo to redvalkrie
? Are there any diffrence in engine 99,00,01,02
I have found that in a 99 G20t the oil filter is on the passenger side on top & some hoses & some other things are diffrent from a 2000 G20t & then they change somewhat more in the 2002.
Can any one please let me know if there are major pros & cons regarding engine difrences, can we swap parts form diffrent years can we adapt newer parts to make the p11 of early years with parts from the 2002.
I drove a 2002 a 99, 2001 & a 2000 all in one day. All G20t's
The 99 felt a little slugish, the 2000 a little more responsive off the line.
The 2001 pretty much the sam as the 2000, but the 2002 was quicker has a couple more hp's & felt better all around more refined!
So my ? is for a 99 can parts from other years be adapted & made to be as good as the 2002?
Than-x guy's!!!!!!!!!!!!!!!
(I hear what you are saying but I feel you are lieing to me, would love to say to BUSH!)
"Don't trip, skip, pinch your forehead"!
1988 CRX Si
2001 CBR 600F4i Silver & black FAST!
2004 Toyota Tundra (TRD)
2002 dodge grand caravan.
Old 09-07-2001, 01:17 AM
Brian P's Avatar
Brian P Brian P is offline
Send a message via ICQ to Brian P Send a message via AIM to Brian P
my understanding was that the only difference between the engines was 5hp more in the '00 and above... and that was soley because of the low restriction muffler/dual exhaust tips. also, the gear ratios are lower in the '00s and over i think. i could be mistaken so dont take my word for it.
Old 09-07-2001, 02:55 AM
Anthony Anthony is offline
I thought that the latest 2002 G20 uses roller rocker cams, similar to the European Primeras?
Owner of Primeraweb, and a 1997 Nissan Primera SRi driver
Old 09-07-2001, 06:42 AM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
2000+ had the new cams...
As for differences between the years... some hoses may be in different places, just minor enhancements, nothing major.
About 99% of the parts on the 99+ are interchangable.
Old 09-07-2001, 06:46 AM
b-b00gie's Avatar
Banned
Thats just Infiniti's answer to a non-technical buyer as to why they had 5 more HP.
I'm willing to bet the new cams and MAF had more to do with it than the muffler... but this wouldnt be a logical answer to give most customers as most have no idea what a Camshaft or MAF is.
Old 09-07-2001, 09:55 AM
redvalkrie's Avatar
Thumbs up
Hey Thanks guy's.
The only reason I was asking because I picked up a G20t 1999 pearl white yesterday & I wanted to know if there were any big diffrences, all solely cause I wanted to know how much work was going to be involved in making up to par & better than the 02,01,00.
So cams & MAF hmm thats about a little over a gran there!!!!
I will be doing the minor things 1st clearing out the lights that every one is having problems with changing the color of the cluster & bulbs, I hope to pick up my new digi cam this weekend will see how much doe I have!
So now I have 2 G's in my garage a 1999 G20t pearl white (manual my car) & a 2000 G20t Obsidian black (auto wife's car).
I already have noticed some diffrences & will keep you all updated on what else I find diffrent!
1988 CRX Si
Old 09-07-2001, 10:02 AM
P10DET's Avatar
P10DET P10DET is offline
I'm not current on the dates of production changes to the P11, but somewhere along the way, Nissan installed the roller rocker engine in the P11. So, this has different cams and rockers (and currently there are no cam offerings for this car in The States). That engine also has a revised crank and no lower engine girdle.
The engine girdle (officially called the Main Bearing Beam) removal cuts windage losses and probably accounts for all of the 5 hp increase.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 09-07-2001, 11:21 PM
Brian P's Avatar
so youre saying that the mufflers are exactly the same? seems kinda odd that they would put dual tip exhaust pipes on a muffler if it had no effect. and hey... whats a MAF?
Old 09-07-2001, 11:26 PM
P10DET's Avatar
I never said anything about the muffler. The question was about engine differences. But, no, I serioiusly doubt the muffler had any effect. Even installing a high flow aftermarket exhaust will only add about 3 hp on an SR20 powered car.
MAF is the mass airflow sensor.
George Roffe
Houston, Texas USA
00 328i
Old 09-08-2001, 01:59 AM
primera_gte primera_gte is offline
Send a message via Yahoo to primera_gte
rumor has it that the 2000 G20 had 10 more HP at the wheels. someone mentioned sport compact car when citing this info. has this been substantiated?
Old 09-08-2001, 10:18 AM
b-b00gie's Avatar
Banned
I'm not sure about 10whp...
But I have seen dyno charts of 2000+ cars doing 124-126whp, while all magazine published 99 dynos were all 118 or 119whp.
Jason (G-Forces) has a 99 and I think his "stock" dyno chart was 123whp. This is the only 99 I have ever seen over 119whp in stock form...
BTW, this is all based on manual transmissions..
Old 09-08-2001, 06:23 PM
slickkedar's Avatar
slickkedar slickkedar is offline
New for 2000 SR20DE:
-Lengthened intake manifold
-Reprofiled intake camshaft
-Lighter weight roller-type rocker arms
-Lighter weight crankshaft
-New piston rings
-Modified swirl control valve
-Double-tipped platinum spark plugs
-Variable capacity muffler
Old 09-08-2001, 10:57 PM
P10DET's Avatar
-New piston rings
The lengthened manifold will lower power
The cam must be reprofiled due to the roller rockers
Roller rockers will add a smidgeon to hp
The lighter crankshaft will add to hp
Piston rings won't make an hp difference
Swirl control valve - not totally certain what this is
Double tipped plats? The SR20 has always come with them
Variacle muffler might help some
George Roffe
Houston, Texas USA
00 328i
Old 09-08-2001, 11:12 PM
slickkedar's Avatar
i dont know really either, i just got that off the engine matrix on freshalloy.com
RESOLVED! 98 99 00 01 02 Rodeo Blower Motor problem wbigsby Rodeo | Passport | MU 2 06-12-2016 10:10 PM
Crate engines, are there any? RISING-SUN 924/944/968 7 04-27-2004 10:33 AM
are there any engine swaps you could do to a sunfire? scyth_0_notic General Discussions 1 08-17-2003 09:17 PM
Body Kits for 00+ 4drs? Are there any? 99TrackerConv Cavalier 2 11-19-2002 02:02 PM
