| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Does anybody have a clue with this check engine light code?
I have an Eclipse GST 1997, and got a check engine light on, with trouble code P1104 (Turbocharger Wastegate Solenoid). I have heard that it is because of the stock boost controller is not plugged in, but the thing is I don't have any aftermarket boost controller installed and have never touched the stock boost controller whatsoever. By the way, where does the stock boost controller located? (It would be great if someone is nice enough to take a picture of its location
) So I can check if it is plugged in properly. Also, does this code have anything to do with the MAF?![]() Please help me out guys, the CEL is so freakin annoying... ![]() |
Re: Does anybody have a clue with this check engine light code?
Actually, you are looking for the BCS, or Boost Control Solenoid. The BCS is located on the passenger side frame rail, directly below where the coolant overflow bottle should be. It is held on with one bold, 10mm if I remember correctly (but I never do.
). Anyway, it should have a plug attached to the bottom and 2 vacuum lines. Make sure both vacuum lines are attached and that the harness is still attached. I'll go see if I can find you a picture. EDIT -> Here you go....
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Yup...it is on the left hand side of the engine bay I would say it is more underneth the upper intercooler piping on the wall there. You should be able to find it...there is probably a loose vacuum line on there.
1998 Eclipse GSX 6 Bolt swap MHI Big 16g FP Race Manifold Apex'i N1 Cat-back Apex'i N1 Downpipe Walbro 255 fuel pump GReddy Type S BOV Turbo XS Boost Controller Balance Shaft Elimininator ACT 2600 RRE 11lb No Name Flywheel Prothane Motor Mounts Tokico Illuminas Advanced Handling Kit RRE Front and Rear strut tower bars RMDSM Front and Rear Sway Bars TRE Stage 2 Tranny ARP Head Studs, Main Studs, Rod bolts |
Thanks for the help guys~ Is there a chance that the BCS is broken or something? Coz I checked today, and everything "seemed" plugged in, except the BSC is hella dirty. should I take it out and clean it?
Can't hurt to clean the electrical connector, maybe it's all rusty or something. It is possible that the BCS is bad, but I wouldn't go to the dealer to get one, because I've heard they are really expensive.
