Old 02-25-2007, 11:38 PM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
DSMlink V3
Is version 3 out yet or is it coming out soon? like within the next month?
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
Old 02-26-2007, 09:06 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: DSMlink V3
it will be a while
now - 2000 civic
soon - 2002 is300
Old 02-26-2007, 07:46 PM
mtcs's Avatar
mtcs mtcs is offline
Send a message via AIM to mtcs Send a message via MSN to mtcs
Re: DSMlink V3
Yeah...im on version 2.5 right now too. The website has lots of talk about a V3 but what exaclty will it have that version 2.5 doesnt have?
1996 ECLIPSE GST
2.3 Storker, 6 bolt, XACT flywheel, ACT Clutch, B&M shifter, DC SPORT Carbon steel strut tower bars, EVO2 exhaust, 1000cc injectors,Aeromoive rail, MBC boost controller, PTE 6152SP, SBR exhaust manifold, TIAL BOV, SBR FMIC, TEIN SS, Walbro fuel pump, AEM EMS, AEM UEGO, FP turbo intake, Aeromotive FPR, Magnus intake, 62mm throttlebody, Stoptech big brake kit, brembo rear slotted discs, Stage 2 Shep transmission (quafe), sparco fighter seats, sparco harnesses
Old 02-26-2007, 07:47 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: DSMlink V3
I think it will be a while too...and considering they only charge $50 to upgrade from V1 to V2 I imagine it will be the same deal...and you can just upgrade when the time comes...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 02-27-2007, 01:17 AM
Re: DSMlink V3
check out the "major enhancements" thread. Looks like V3 is going to rule.
now - 2000 civic
soon - 2002 is300
Old 02-27-2007, 08:14 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: DSMlink V3
Copy/Paste? Some of us non link users want to see!
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-27-2007, 02:32 PM
mtcs's Avatar
Re: DSMlink V3
twdorris
Administrator of DSMlink.com
Major enhancements thread, part 2
The following summarizes many of the suggestions presented in this thread as well as roughly where we stand on them. These are items under consideration for the next major upgrade release of DSMLink (both 1G and 2G).
2G ONLY - ALREADY PRESENT ON 1G
1. Memory board
2. Static timing adjustment while nitrous is activated. Also increase the upper limit on the RPM window.
3. Clear knock on clutch input
4. Option to lock in open loop so as to free up FrontO2 input for other things
5. Injector disable
SERIOUS CONSIDERATION
1. GM MAF direct interface to ECU
2. Closed loop wideband functions
3. Additional solenoid controls. Probably define sets of parameters and have each output controllable by any "type" of parameter set.
4. Security code before startup
5. Input smoothing in the ECU for all custom inputs, including possibly the RPM signal.
6. Overboost timing adjustments; perhaps coolant temp based adjustments as well.
7. Extended RPM and airflow ranges on fuel and timing maps.
8. Direct access to large parts of the fuel/timing map. Accessing all of both maps may be prohibitive, but we'll try.
9. Full time speed density option
10. "2-stage" knock retard light
INVESTIGATE AND CONSIDER
1. Boost control
2. Fuel/timing adjustments based on amount of time on full throttle (really what people need that talk about load or gear based tuning)
3. Control over knock retard logic
4. Coil dwell time control
Thomas Dorris
1996 ECLIPSE GST
Old 02-27-2007, 02:56 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: DSMlink V3
sounds pretty bad ass... I'll hopefully have link in the Talon by the end of the year...(shit, hopefully it'll be running by the end of the year)
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 02-27-2007, 03:34 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: DSMlink V3
I need to come up with something like that for n/a ECUs. I'd be the first to install that. Damn I feel lonely.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-27-2007, 05:34 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: DSMlink V3
I can't wait for that!!!!
DSM geek
Old 03-02-2007, 05:58 AM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Re: DSMlink V3
i hope there is alot of new stuff to it
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 03-02-2007, 06:23 AM
Thor06's Avatar
Jizzed In My Pants
Re: DSMlink V3
I dont know, I think V2 will be just about good enough for me. I know I will be able to put V3 to use but I wont be pooping my pants over it.
Old 03-08-2007, 09:37 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Re: DSMlink V3
I know how you feel. I hope to have my eclipse up and running by the end of June. It will be officially out of commision for a year on the 15th of this month.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
