Go Back   Automotive Forums Car Chat > Ford > Contour
Old 02-25-2007, 07:08 PM
teddie1960 teddie1960 is offline
Air Conditioning Pressure Switch Connector (99M03)
Currently I'm replacing the wire harness in my 1995 ford contour 2.0 for the recall 99M03 which my car was over the 100000 mile mark when it came out. My car does not have ABS and it calls for me to replace the fan control harness, fuel charge harness and install a power distribution harness overlay. While installing the overlay harness step 34 says to disconnect the air conditioning pressure switch electrical connector. Then remove the purple wire and insert the terminal from cooling fan jumper branch into the air conditioning pressure switch connector. Can't find this connector anywhere. Could this be the A/C high pressure cutout/fan switch connector??
