Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 02-25-2007, 02:40 PM
heyfarmer heyfarmer is offline
89, V6, Doesn't Start
just bought this truck, it was running but rough, it had a rag stuck in the fuel tank. i put a new fuel cap on, new gas and a can of dry gas, bought a new fuel filter and turned on the fuel pump while the filter was off, got clean fuel and a strong stream. put new filter on, and replaced dist. cap and rotor, got good spark, and fuel pressure at the fuel rail. it seems to be not getting fuel, it trys to run when i'm cranking on it, and pumping the accelerator. got 115,000 miles, ext cab, 2 wheel dr. new air filter. any suggestions would be great, thanks.
Old 02-25-2007, 07:20 PM
22revguy 22revguy is offline
Re: 89, V6, Doesn't Start
Not to insult your intelligence, but did you put the cap and rotor back on according to their old position? Rough running prior too could have been bad gas or dirty injector heads. Hope it helps.....
Old 02-27-2007, 10:14 AM
Yes, i made sure the cap, rotor and wires was on correctly. I thinking something with the EFI. Where is it and what do you replace or check for. Thanks
Old 03-04-2007, 08:53 PM
jake jake jake jake is offline
there is a box like part just to the right of the master cylinder in my 4x4 V-6 xcab Toyota 1989 pickup [the part is on the driver's side; its nearer to the back firewall, not the air firtler box]
the box has a wire that runs from the box thru the firewall [the wire seems to run right in back of the dash board where the speedomoter is]. anyone know what this part is?
anyone ever have it replaced? if so, what did it cost?
i get a funny noise when i first start the 4x4, put it in drive, and start to move. the noise seems to be coming right from around that box like item.
after i drive the 4x4 for 15-20 minutes and its all warmed up, the noise seems to fade away [or at least it is much much much harder to hear].
could that boxlike item be the speedomoter box and cable???
help!!!!
Old 03-04-2007, 09:03 PM
J-Mech J-Mech is offline
jake jake you need to try to repost in a new thread or no one will get it. heyfarmer what kind of truck
