Old 02-25-2007, 12:34 PM
MA8 MA8 is offline
Problem with glass
Hi,
Need your advice. How can I remove scratches from the glass? I tried to sanding this with 2000 paper but no result. Have you any other ideas?
Old 02-25-2007, 12:52 PM
stevenoble's Avatar
Re: Problem with glass
I always use a little Tamiya rubbing compound to remove fine scratches from my glass parts.That looks like quite a deep scratch though with a little patience I think you should be able to remove it.
Steve Noble
Old 02-25-2007, 01:08 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Unfortunately, that's not a scratch. That's where two masses of molten plastic met in the mold during casting, and they didn't fully combine. I don't think there's any way to remove it, no matter how much you polish.
PHOTOBUCKET SUCKS
Old 02-26-2007, 06:23 AM
MA8 MA8 is offline
Many thanks for response. That's sad, I have a two kits from Fujimi and both have a same defect of glass parts.
Old 02-26-2007, 06:50 AM
rallymaster's Avatar
But you may be able to replace the part by cutting the same one in a rodoide sheet...
I think it will be possible as it's not a too much curved or complicated part for what I see of it.
Phil
Old 02-26-2007, 08:41 AM
MPWR's Avatar
Yeah, what Phil sed. Carefully cut the side window off to 'roll it down', or replace it with some flat clear plastic sheet.
PHOTOBUCKET SUCKS
Old 02-27-2007, 11:43 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
That looks like a scratch to me. Sometimes you really have to start out with a more aggressive grit to get them out, then go to finer paper & polishing cloths, finally Novus 2 and 1.
Bob
Old 02-27-2007, 05:35 PM
hirofkd's Avatar
hirofkd hirofkd is offline
That's a weld-line, and you can't remove it by sanding (fairly common in Fujimi kits, but does happen in Tamiya kits, too).
>>MA8
Since you have two kits, cut that portion off, and use it as a master for thermo-forming (like heat-and-smash method or vacuum-forming) and make window parts for both kits. That'll save you some time.
Hiroaki Fukuda
