Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-25-2007, 11:42 AM
j_aguilar88 j_aguilar88 is offline
SR20det boost hesitation
hi i resently swapped an sr into my 240, it was fine until this really cold morning i started it but it kind of like hesitated but dissapeared after i left it on for around 5 minutes, then when i started driving it i could feel it hesitating again when its going into boost, i cAN go into about 3psi as long as i dont slam on the pedal hard and keep my rpms at around 3500-4000 then it hesitates, i try not to push it to prevent detonating but i dont know what could be the problem. help will be apreciated
Old 02-25-2007, 12:16 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: SR20det boost hesitation
thats kind of a vague description. how cold was it outside when this happened? and what exactly do you mean by hesitates? are you using a stock ignition system or did you switch to a distributor? how full was your gas tank?
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 02-25-2007, 12:27 PM
stock ignition system, just exhaust and walbro fuel pump, it was about 12 degrees outside when it happened, as it starts going into boost it goes up to around 3-4 psi then it feels like the car falls on its face but then grabs again but kind of hesitates again, i dont want to push it hard because i dont want to risk detonating.
Old 02-25-2007, 03:34 PM
HoosierDrifter's Avatar
HoosierDrifter HoosierDrifter is offline
booooooooost leak
71 Camaro RS/SR'ed 92 240sx
Old 02-25-2007, 03:44 PM
Originally Posted by HoosierDrifter
booooooooost leak
what would be a way to cheak for a leak? i went through the pipes everything seems fine
Old 02-25-2007, 04:50 PM
well you could do what we do to check for leaks on tires... get a spray bottle.... pour some liquid soap in it and fill it with water. spray everything thats gonna be under pressure(intake, cold pipe, hot pipe, intercooler).. and check everyclamp ( i double clamped everything on mine) run it... boost it... and check for any bubbles on anything you sprayed down.. and spray generously. even check your bov for a leak. also make sure theres not extra air entering the motor thats not read by the MAF
